Using 2.0.2146 XP Pro(sp2)
After creating a menu, I am unable to modify the font either from the menu tool bar, or in the settings tab. The only way I can change the font is to trash the project, set the default font in the settings tab, start over.
Am I doing something wrong? Thanks in advance.
So select buttons then change font.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Thanks, I'm a bozo
I came here today to say "nevermind" I eventually figured I needed to highlight the button(s).
Sometimes the obvious escapes us all.....
MTS unable to play in WMP11/unable to edit in Movie Maker
By xxx4reggie in forum Newbie / General discussionsReplies: 6Last Post: 22nd Nov 2011, 23:04 -
MultiAVCHD - unable to make menu
By WARRENFRALEIGH in forum Authoring (Blu-ray)Replies: 3Last Post: 12th Sep 2011, 14:03 -
Unable to burn DVD, unable to access the Video_TS.ifo.
By Asymmetry in forum Newbie / General discussionsReplies: 3Last Post: 17th Aug 2008, 23:02 -
Possible to Modify MKV?
By BlaenkDenum in forum Video ConversionReplies: 3Last Post: 3rd Apr 2008, 02:43 -
TMPGEnc Author Version 2.0 - Unable to make a DVD with a motion Menu
By tug_hill2 in forum Authoring (DVD)Replies: 5Last Post: 28th Sep 2007, 00:37
