I have created a DVD, with all the chapters in place and I'm very pleased with it. At least I was until I saw that I have put the wrong date on the menu.
Is there any software that will let me edit the menu of a DVD whilst leaving everything else in tact.
If anybody could help me with this I would appreciate it.
Thanks.
Thanks for the tip. I downloaded it but I can't seem to do what I want to do. Which is change (or over-write) some of the text on the menu.
One detail on the DVD is wrong and I just can't face having to re-author the whole thing again. -
is it a still menu or a motion menu?
you cannot change the text if it's within the video menu easily but it's not impossible
. It's probably easier to create a new menu to swap
if it's a still menu then you can do it with DVDRemake Pro (I think) but to use it just once for a still menu swap then is it really worth it?
either way you shouldn't have to reauthor the whole DVD though as you should be able to just swap the menu if you create a new one
there is a guide here:
http://www.dimadsoft.com/dvdremakepro/ht_customize_menu_background.php -
And here, using freeware:
http://forum.doom9.org/showthread.php?p=555936#post555936
PGCEdit menu editing
By gbabione in forum DVD RippingReplies: 3Last Post: 31st Aug 2010, 06:13 -
Editing menu
By heof in forum Authoring (DVD)Replies: 1Last Post: 24th Jul 2010, 15:49 -
Complex Menu Editing (Probably)
By Instant Martian in forum DVD RippingReplies: 20Last Post: 18th May 2010, 15:08 -
Editing original menu.?
By cavusozkan in forum Authoring (DVD)Replies: 4Last Post: 16th May 2010, 14:18 -
Editing Motion DVD Menu
By gallardo in forum Authoring (DVD)Replies: 5Last Post: 6th Nov 2007, 22:12
