ive asked for this before and it seems that no-one can help me out well i'm sorry but i aint willing to believe that so stop being shy and share the knowledge you got whoever you are!
hacks needed for standalone dvd player: PACIFIc PDVD-1000
comeone lads and lassies somebody goto know
i can not find anything even confirming the existance of the make and model you are requesting info for. if you could please provide a link showing this player in any way perhaps i can help a little more
peace out,
dumwaldo
AWW MA! you know i'm not like other guys. i get nervous and my socks are to loose. -
I have just baught a p-dvd 1000, nice little machine it is too for the money..
anyway, if anybody does no of a region hack i would be greatfull too
right.. think ive sorted this but i havn't got a foriegn region disk to test it but iam 99% sure its done..
press open/close then key in 8421, a region code menu should appear ( it did on mine ) press enter untill the desired region number is shown then press open/close, I believe that multi region is 9 but iam not 100% sure cus ive not tested it yet, but region 2 still play fine.
ill let ya know tommorow
<font size=-1>[ This Message was edited by: Alcohol on 2001-12-27 18:27:32 ]</font> -
i have 2 m8's that confirm the hack works
i'll have to test tommorow
cheers m8 -
On 2001-12-27 12:59:09, wilbee wrote:
i think this scan of the instruction manual should confirm its existance
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
results to pacific pdvd-1000
http://www.google.com/search?q=pacific+pdvd-1000
results to pacific p-dvd 1000
http://www.google.com/search?hl=en&q=pacific+p-dvd+1000
just so you understand why it is important to give accurate information.
i couldnt find it because i was looking for a non existant model number.
anyway glad you got the help you needed and yes Alcohol, 9 is correct for the code for multi reigon.
peace out,
dumwaldo
I think I am gonna get the Sony D5000. question about auto focus
By jbitakis in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 7th Aug 2010, 17:59 -
OK Gonna buy the HD palmcorder.....now what?
By gom in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 20th Jun 2009, 14:27 -
I know I've got a stupid question, but I'm gonna ask anyway about FC studio
By sirN in forum MacReplies: 4Last Post: 16th Apr 2009, 00:59
