Is Arita the "cheaper" "won't last as long" "more coasters" disc of Ritek?
Are Ridata and Arita the same or is the Arita Process totally different thus the new name?
Arita are indeed the lower grade spin-offs - they get rejected for all sorts of things and if you get a good batch, they're "OK".
However, you should expect dye flaws that stop you burning to them in the first place, lots of errors near the end and at the very least, overprints (one label printed over the original) and possibly fingerprints on them from being handled.
Ritek are hardly expensive these days, you're probably talking less than a penny / cent per disc difference so personally I wouldn't risk it. You just don't know what you're going to get !
RiData - what happened to them?
By akkers in forum Authoring (DVD)Replies: 4Last Post: 23rd Apr 2012, 11:24 -
Ritek RiData G05 vs RiData Pro Series - Anyone know the difference?
By DVantrease in forum MediaReplies: 5Last Post: 1st Jan 2009, 15:48 -
How about some RiData DVD+R DL discs...?
By JohnnyBob in forum MediaReplies: 31Last Post: 26th Apr 2008, 08:30 -
Verbatim or Ridata DVD-R
By jyeh74 in forum Newbie / General discussionsReplies: 3Last Post: 4th Mar 2008, 01:57 -
Ritek Ridata DVD-R 4X G04 where or better?
By Illicious in forum MediaReplies: 8Last Post: 15th May 2007, 10:41
