greetings all,
I have searched endlessly here and on google and no luck in looking for a problem similar to mine, so here goes
1 x Sony Stereo VCR with RCA outputs
1 x Panasonic DVD Recorder with RCA inputs
VCR Tape Recording is a home movie plays fine on TV
via RCA cables I connect the VCR to The DVD recorder and record the material.
It plays fine on TV
I then use TMPGENC Author 1.6 on WinXP with 1 gig ram and no virusses no spyware and 2 x 300 gig HDD's with a LG DVD-DL DVDwriter to read the contents of the DVD ram, it then comes up with unable to continue ... stream is mix format 16:9 and 4:3
I copied the file off the DVD-RAM and opened it in MPEG2VCR and this link shows what one frame of the stream looks like except the whole stream is like this (this is a home Movie) ---> http://kjaere.dyndns.org/problem/problem.jpg
I have tried setting the DVD recorder in both 16:9 and 4:3 and i get the same error, I have tried transfer instead of the RCA to use the TV tuner instead, and the same result happens. Note this does not happen when I record Digital TV, Satellite TV or analog ( one exception when we have a bad signal from Channel 10 Melbourne the same effect happens)
Ok thats the problem, hopefully someone will recognise the problem from my link --> http://kjaere.dyndns.org/problem/problem.jpg and may offer possible solutions or work arounds
I thank you in advance
TmpgENC DVD Author has a problem with mixing video in mixed formats. You may be able to import it under "add DVD video" from the DVD-RAM disc.
I've had the same error that you're seeing on video using both an E55 and E20. Once was on a camcorder transfer to the front AV connections (E20, E55), recently to the rear AV connections (E55, which rules out input as the problem). I believe it may have occurred when using the flexible recording mode - or it may have been a problem DVD-RAM disc. I've never seen it when using DVD-R media??? While it's only happened a few times during the past 3 or 4 years, it's extremely annoying when editing the video - as is having to re-record. I'd suggest recording again in 2 hour mode (using the same disc - if possible) and see if it clears up. -
I currently use the "add DVD video" and that is where i get the problem, + i have it set to 2 hour mode currently (I never use flexible recording mode), I have checked the same disk by erasing it and recording something off satellite and TMPGENC author 1.6 will import it fine with "add DVD video" .. The Only Thing I have not Done is use a DVD RW, I will try that and see if i get different results, and post my result hereOriginally Posted by classfour
Thank you for replying, ill try a DVD-rw and see if that makes a difference, & I might try it in 4 hour mode
Fingers crossed
recording test pattern on a vcr from PC
By mammo1789 in forum Capturing and VCRReplies: 11Last Post: 13th Apr 2012, 10:59 -
Need a DVD Recorder Or better VCR for Recording VHS to DVD
By Konfusion in forum DVD & Blu-ray RecordersReplies: 1Last Post: 9th Apr 2010, 00:09 -
Recording in VCR Mode
By mapmaker in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 26th Oct 2008, 19:23 -
HDTV VCR recording, VHS TAPE?
By jb66 in forum Newbie / General discussionsReplies: 4Last Post: 22nd Oct 2008, 18:45 -
recording copy-guarded material with VCR/DVD re-writer combo?
By corneileous in forum Newbie / General discussionsReplies: 16Last Post: 21st Jan 2008, 18:56
