What's the best AVI codec to use?
Depends what you want to do.
DV is great for editing and cutting (all keyframes) but large files. Huffyuv is lossless but also creates large files and picvideo mjpeg is also a good codec.
Many people use Divx or xvid because the compression ratio to filesize is excellent. There are now newer H264 based codecs which need maximum system resourses for capturing but can deliver good results when re-encoding from dv or huffyuv. Just too many to list.
I use DV format as an intermediate codec because of my camera but most other times use divx or xvid for tv captures. -
XVID. Without a doubt.
Oh yeah - https://www.videohelp.com/forum/viewtopic.php?p=1388992#1388992If in doubt, Google it. -
try divx6.....
yes,,, i've been quiet impressed with the quality you get a low bitrates (450).... on a cbr single pass....
but xvid is good too.... the only reason ppl do divxx is so they can play it on thier set top box!!!COOKIEEE!!! -
My choice is Xvid, too. Good quality, free and easy to handle, I mean, no problems with conversions.
Thanks, that narrows down my choices.
Is there some bitrate conversion from MPEG to XVID and other AVI codecs?...so I know how to maintain the quality, because I want to use constant bitrate instead of variable.
v210 AVI codec
By christianolovesvideo in forum Newbie / General discussionsReplies: 1Last Post: 17th Jun 2009, 14:59 -
DV-avi codec error????
By crb119 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 12th Jun 2009, 07:49 -
DVD to AVI but no codec
By Cazz in forum DVD RippingReplies: 6Last Post: 27th Mar 2009, 10:10 -
How to get avi codec for mac????
By balonglong78 in forum EditingReplies: 14Last Post: 9th Feb 2009, 20:13 -
The best AVI video codec
By hzgg2 in forum Video ConversionReplies: 1Last Post: 2nd May 2008, 17:19
