OK im going to do a test on this. Here are the specs.
[MPEG-1]
Video length - 200 frames
Framerate - 25FPS
Rate control - CBR2520
Aspect Ratio - 4:3 625Lines
Audio - 224/44khz
File Size - 2,891,780
Encoding Time - 141 Seconds
[MPEG-2]
Framerate - 25FPS
Aspect Ratio - 4:3 Display
Audio - 224/44khz
File Length - 2,791,124 bytes
Encoding Time - 145 seconds
Well i guess i proved myself wrong. MPEG-2 is smaller, as for quality, the quality on both files is identical, there isnt any noticable difference
Results 31 to 37 of 37
[MPEG-1]
Framerate - 25FPS
Audio - 224/44khz
[MPEG-2]
Framerate - 25FPS
Audio - 224/44khz
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
Do the same you did on a very fast scene and see what happens to the "blockiness" on the MPEG-2.
Its exactly the same, the only difference is the mental difference, which you make the choice of. Ive made plently of MPEG-2 SVCD's with almost no blocks at all.
Of course 480x480 (SVCD Standard) will have more blocks than 352x240 (VCD standard) but that is because of RESOLUTION!!! NOT MPEG-1 , MPEG-2! at the same resolution, and same bitrate, they look identical, regardless of the pace of the scene, you are imagining things, nothing more, nothing less -
Just sit back and laugh. I shouldve dont that
Free software to split large MPEG-PS file into many small MPEG-PS files?
By videonewbie22 in forum Newbie / General discussionsReplies: 9Last Post: 5th Jul 2018, 19:16 -
avidemux audio sync problem with MPEG-2 - alt. way to cut mpeg-2
By graysky in forum LinuxReplies: 8Last Post: 6th Nov 2011, 21:02 -
No audio when saving .MPEG file from VOB stream using MPEG Streamclip?
By Bix in forum MacReplies: 3Last Post: 25th Jul 2010, 17:12 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 04:40 -
720x486
By J. Baker in forum Newbie / General discussionsReplies: 15Last Post: 12th Sep 2009, 12:00
