Hi all, here's the deal...I captured 14 different video clips with iMovie HD, now I captured each one separately and saved them under different file names. I now want to import all the clips into the timeline so I can then export them to iDVD with the "Play All" and "Scene Selection" buttons. But every time I try to do that, I get an error saying that Quicktime cannot parse the file, and then an Error -43. Is it possible for me to import these clips into iMovie HD? I would think I should be able to, but I keep getting this Parse File Error.
The reason I captured it this way was because I wanted to use the 12 drop zones menu in iDVD, and if I capture one big file then I can't...so can anybody out there help me? Thanks in advance!
Hunter
How are you importing the clips? By choosing the iMovie project package in File/Import? IMO it would be logical for that to work but it doesn't.
With iMovie HD you have some options to do that -- a) is preferred but it copies all underlying media clips in their unedited form behind the scenes:
a) In project 1, select the desired clips, Edit/Copy, open project 2 and choose Edit/Paste, and wait a while.
b) In project 1, export as Full Quality DV, and import THAT to project 2 (notice that the .dv import doesn't have a progress bar so be patient when importing a multi-GB .dv file!). Or use this shortcut:
http://www.sjoki.uta.fi/~shmhav/iMovie_HD_bugs.html#quick_DV_import
c) Copy the /Cache/Timeline Movie.mov out of the project package and import it to the other project.
http://www.sjoki.uta.fi/~shmhav/iMovie_HD_bugs.html#package
Best way to import .mts files to iMovie?
By S4Shredr in forum MacReplies: 4Last Post: 22nd Jul 2011, 14:45 -
Import via AVDC-55 to imovie '09, audio has vanished.
By sackreiter in forum MacReplies: 4Last Post: 25th Dec 2010, 13:54 -
easiest way to import footage from DVD to iMovie?
By cinclodes in forum MacReplies: 3Last Post: 27th Oct 2010, 11:07 -
Canon ZR50 to imovie import
By tlcohn in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 16Last Post: 18th May 2010, 12:03 -
MPEG-2 video/audio to MP4 or anything iMovie will import
By quella in forum MacReplies: 9Last Post: 3rd Dec 2007, 20:07
