Hey
Is there anyway to resume conversions from rmvb to mpg in TMPGEnc? One half of the file will take 8 hours to convert so I'm wondering is there anyway I can stop/start, re open it and it will resume it from the point I left it.
Results 1 to 10 of 10
nope. once you start the only option is stop and from there, no resuming is possible. one option you could try is to set the program's priority to low and let it run in the background on unused processor cycles. the other is to let it run overnight and it should be done in the morning.
As puss said, theres no "pause". I usually encode at nite when I sleeping or during the day when Im at work. Or, just before bed, setup a batch and let it encode all nite and all the next day, when I get home from work I have 3 or 4 DVD ready MPEGs to burn.
I have been into computers since 1980. Ive been tinkering with DV in one flavor or another since 1990. -
What about using the stream option? Can you like record say 5 minutes at a time - each a different file and then somehow join them into one video?
Read my blog here.
Different types of codecs give different levels of compression and different levels of quality. Bitrate is the overriding factor, but two different codecs can give different results at the same bitrate. Codecs are like apples and oranges, and can't ne compared on size alone.
CCE has a demo that watermarks the output.Read my blog here.
i wish ALL these damned video tools had the option to stop & resume later...!
I am just a worthless liar,
I am just an imbecil -
The issue is that temporal compression relies on knowing both the frames before and the frames after the frame you are compressing. It might be possible to break and resume on an I-frame.
This is one of the reasons effects people render to still frames and not to video filesRead my blog here.
TMPGENC question
By triumph2004 in forum Newbie / General discussionsReplies: 0Last Post: 22nd Aug 2008, 23:21 -
TMPGEnc question.
By Hal05154 in forum Newbie / General discussionsReplies: 1Last Post: 14th Nov 2007, 08:20 -
TMPGEnc Question
By dafoe in forum EditingReplies: 5Last Post: 12th Oct 2007, 04:38 -
FitCD / TMPGEnc question
By Seroster in forum Video ConversionReplies: 4Last Post: 3rd Sep 2007, 12:34 -
TMPGEnc XPress 4 Question
By Anakin in forum DVD RippingReplies: 1Last Post: 24th Aug 2007, 23:08
