    Sep 2005
    u.s.a
    What is the best program to create menu's.
    I am a newbie using adobe premiere.
    I will be using this for wedding movies I record.
    thanks in advance..
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    adobe photoshop, paintshop pro or mediachance dvd menu (also found in dvd lab pro)
    you will still need something to author your dvd's as none of these (except dvd lab) does this - nor does premiere
    Sep 2005
    u.s.a
    Cool..I do have and use adobe photo shop. What are the advantages of
    dvd lab pro from dvd lab?
    Apr 2004
    Miskatonic U
    Look at the table at the bottom of this page
    http://mediachance.com/dvdlab/dvdlabpro.html
    Read my blog here.
