Can it be done? ffmpegx is not working for me. Is there a way to import the DVD video straight from the DVD to Final Cut or someting similar to that like putting the DVD video straight to miniDV where I could obviosly then import to Final Cut.
Normal steps: Extract the VOB, demux to MPeg2 and audio, decode audio (if AC-3) then import the elements needed.
http://www.kiva.org/about -
I prefer MPEG Streamclip but you can also use DVDxDV, Drop DV, Cinematize, Toast, Capty MPEG Edit EX etc. I have had good success with ffmpegX, too. All those apps work only with unencrypted material.
http://www.sjoki.uta.fi/~shmhav/SVCD_on_a_Macintosh.html#edit_convert_MPEG
Final Cut Pro 7 exits when importing avchd folder
By jovannig in forum EditingReplies: 0Last Post: 23rd Jan 2010, 17:24 -
Final Cut Importing Woes (non-DV files)
By panhype in forum MacReplies: 2Last Post: 15th Jul 2009, 16:20 -
Strobe importing VHS to Final Cut Pro
By Huntr777 in forum MacReplies: 0Last Post: 15th Apr 2009, 14:59 -
Importing DVD Files for Use in Final Cut?
By The Monkees in forum MacReplies: 8Last Post: 29th Dec 2007, 09:20 -
importing commercial DVD's to final cut
By aquafinity in forum Newbie / General discussionsReplies: 0Last Post: 24th Jul 2007, 16:31
