Using 2.0.2146 .
Seems to convert and burn fine but when put in standalone Menu loads, music plays first clip is highlighted. pressing Play or Up/Down does nothing, menu just sits there.
Previous version worked fine, just going back to it now to retry.
Any ideas?
Results 1 to 12 of 12
Have the same problem. The preview window doesn't work.
And in my Stand alone DVD player the screen stays black.
Did an older version resolve your problem?
Guido -
What happens in a software DVD player?
The menu popsup. I can select the buttons and start the different movies. But I never see the menuitem being selected.
Guido -
guidorobben:
In order for me to investigate: Can you use the following dummy mpegs:
http://www.svcd2dvd.com/samples/dummymovies.zip
And knock up a sample DVD which exibits this? Can then upload to my ftp along with the log & the s2d file?SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
I did some more test and the funny thin is. They work like they should.
Ik looks like this one a one time error. The only thing that is different is a reboot before I did they others.
Guido -
ok. Thanks for the email. Let me know if it happens again.
CBSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
OK, tried everything I can think of, still having problem. If I make a DVD with a menu it will load the menu, play the music and highlight the first film, but I can't select another menu item or play the one that is selected on standalone.
WMP The Menu items won't highlight but I can select and play them
VLC Same as standalone but can't select items.
I did a full reinstall on laptop, next to nothing installed. Got all the .NET updates.
Used several different discs.
If I uninstall latest version and install Version 2.0 it works fine.
Any ideas? -
With the latest build I was able to reproduce the problem with the dummy movies. I have send send you the info by mail.
Guido -
Yep - i got it. I will take a look ASAP. (Can you send the .S2D projct file too please?)
Problem with fresh PC system build - unusual instability
By PartingShot in forum ComputerReplies: 24Last Post: 6th Oct 2010, 20:36 -
Latest HCenc build (10- 20 - 2009)
By freebird73717 in forum Newbie / General discussionsReplies: 0Last Post: 23rd Oct 2009, 18:29 -
ever had this menu authoring problem before?
By uglijimus in forum Authoring (DVD)Replies: 5Last Post: 22nd Oct 2009, 14:06 -
Movie Collector 5.2 Build 5 problem
By logannsan in forum ComputerReplies: 0Last Post: 3rd Oct 2007, 18:53 -
Menu Problem - Skipping
By vinnyv07 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 30th May 2007, 19:17
