    Feb 2004
    Australia
    This guide is on bovs as used in dvdauthorgui , using the gimp for all editing and ms paint to save out as a 16 colour bitmap
    This is because the gimp only supports bitmap output in rgb at 24 colours , and not 16 colours .
    For those using linux , please check out xnview for a linux version , as it can save out the images in 16 colour format ready to go .
    http://www.xnview.com/
    I'd like too thank liquid 217 for there advice and futher input , which is why this guide exists for newbies or anyone wanting there own buttons for there projects .
    Those with jasc paintshop pro (not free) , can create these buttons easily , just follow the rules specifically to colours used , the number allowed per picture , and format .
    The rules :
    No picture may contain more than 4 colours (black is background , is not seen in playback of menu )
    Only these colours specified below will work .
    (well , not entirely sure about that , but stick with those mentioned would be easier)
    The gimp - being freeware , is accessible to ALL .
    Buttons can be any size , but prefer to keep them the same size as used by dvdauthorgui , they look cooler ...
    The colours by hex value :
    That third down on the left is 0,0,128 .. opps
    These colours are from one of the buttons in dvdauthorgui , so we know they work .
    The average button is 90pixels x 90pixels , so that would be a starting point to work from , so lets go .
    For this guide , I am using some pictures from a clipart collection , so here is a simple picture to use
    I'll leave the arrow out , and just use the paw print for my needs ... so open gimp .
    Click File , Open
    E is where my picture is (double click) , then in other window , navigate down to file (double click it) , to open
    Right click on image and choose , View , Zoom , 8:1 to enlarge it enough to work with , then grab the lower right of the window and drag it open
    to show the whole image .
    Right click on the image and select from menu , Image , Mode , RGB , this will when finaly saving as bmp , produce 24 colour bitmap images .
    Now as for this picture , all that is black will be painted for this guide , blue (0,0,255) , the area in a dark grey will be dark blue (128,0,0) , and background black (1,1,1)
    The alternative will use light green (0,255,0) , dark green (0.128,0) around in that dark grey area , and leave that black area alone .
    Each image will be saved as a different image in bmp format .
    This image size initially is 47pixels x 47 pixels , a little small , but could be scaled up , but I wont do that now , just the paint bit .
    You will notice the pointer in that black square area , double click that and this window appears next .
    In the RGB values , I have chosen to start with my blue , so 0 is placed in R , 0 in G , and 255 in B , then click close button .
    Now the paint tool , but first , click on the main gimp tool box , File , Dialogs , Brushes , and this appears
    Choose the smallest dot available when working in small area's ... now to paint , I prefer the pencil as it allows me to only paint each pixel .
    Here is the image so far ...
    Thats 0,0,255 done , now back and change to 0,0,128 (dark blue) for those grey area's , and here that is ...
    Just hit CTRL + Z if you mess something up ... now the final colour 1,1,1 (black) , and here is that pic ...
    Now , on the picture , right click and choose , File , Save As
    I have name it "dvdcolourblue.bmp" for now ... so here is my altrenative image file , done the same way .
    The blue one is is my default button , the green one is my action button (performs action as required) .
    To finish with , open each picture in ms paint , then File , Save As , change format too 16 colour bitmap , and there ready to go to work ...
    Well , from here on , you should have a good understanding of how to produce buttons for dvdauthorgui in the gimp , just remmember the rules concerning colours , oh , and format required .
    Size dosent matter , but keep them below 120pixels x 120pixels would be nicer looking ...
    Before we finish , here's a snapshot of ifoedit playing back one of my projects .
    The button you see here was created using pixia ... that was me screwing about trying to figure the buttons in pixia , and it too worked ???
    Looks like an artist sitting down , painting .... just me fiddling about to see what other freeware paint programs can create buttons for dvdauthorgui ...
    Of course , thats from my "Dvb for newbies" dvd I have been compiling over the last 2 years as a teaching guide while they work on their pc's .
    All the tools are located on a cd so they have access to all the free tools , and guides I have created , in a simple to follow format .
    Other buttons so far :
    And many more ... hundreds even .
    Some 2 colours , 3 colours , and 4 colours .
    Wont be happy till I have a minimum of 500 I think , by then I'll be ready for something else ... more pcgedit guides ...
    Just an addon : Mwsnap can load you button graphic's and flatten then down to 4 bit ... another handy feature as to why you should have mwsnap in your tool box ...
    Updated note : For the gimp output 16 color use ... image > mode > indexed
  2. Free Flying Soul liquid217's Avatar
    Feb 2002
    Wow, excellent work. I would like to include these in the dvdauthorgui installer, with your permission of course.
    I do have one point to make. Its something I have been thinking about, but have never really said anything. The Aspect Ratio of all of these buttons are 1:1, but if they are authored onto a menu, they will appear squeezed in slightly (moreso for 720,480 NTSC). this means it may be necessary to create 2 sets of buttons, one for NTSC, and one for PAL. What do you think?
    Again, great work.
    Feb 2004
    Australia
    I think this is prone too converted menu's , and not the actual buttons if used with raw inputs as required in dvdauthorgui when creating a new project .
    All appears fine in my ntsc project .
    Converted menu's from pal 720x576 to ntsc 720x480 , tends to squash things about , and in reverse , it stretch's them out in height .
    Menu's with characters or substantial animations are the most affected .
    In case of the button problem , I use a sub ripping tool to grab a snap of the buttons , and reconvert them for reuse , then its a matter of finding a suitable solution for pal to ntsc downsize , and there are a number of ways to do this , but not all will be happy ... in those case's I say go buy it .
    I prefer to build my own menu's , thus avoiding several problems , and reuse the reconverted buttons , this allows me to completely reuse all the commands previously used by this menu .
    Most are happy with the way I do it , and if the original menu has never been seen by the person watching it , then there none the wiser ...
    Well , I think the time has come to show users my way of correcting audio sync issues ... so I'll get too this guide and have it posted before saturday .
    Which reminds me to find my pooh bear collection , thats just got to be converted ... for the kids .
    Feb 2004
    Australia
    Another tool , better than ms paint is Free Image Editor found here : http://www.askedfiles.com/ ... it's free and packed with feature's .
    Usefull tool for designing button's for dvdauthorgui ... and simpler .
