HI
I'VE BEEN USING DVD SHRINK FOR A WHILE, I DID A FORMAT TO MY PC AND WHEN I REINSTALLED DVD SHRINK I DECIDED TO USE THE 3.2 VERSION, THE PROBLEM IS THAT I TRIED TO BURN A DVD WITH DVD SHRINK AS I HAD BEEN DOING BEFORE, BUT IT HAS ALREADY DAMAGE ME 2 DVD-R, WHY I AM NOT ABLE TO BURN DVD-R AGAIN?? COULD I BE MISSING SOMETHING??
BY THE WAY I HAVE ALREADY REINSTALLED THE 3.1.7 VERSION, BUT I DON'T WANT TO TRY IT AGAIN BECAUSE IF I'M MISSING SOMETHING MAYBE I COULD DAMAGE AGAIN THE DVD-R
REGARDS,
PD THE FILES COPIED BY DVD SHRINK ARE IN MY COMPUTER RIGHT NOW
Since DVDShrink has no burning abilities on its own, the problem lies elsewhere.
Personally, I use Shrink to create ISO, then burn ISO with DVDDecrypter.
/Mats -
Maybe you need to install / reinstall an ASPI layer?
Sabrowww.sabronet.com - It's all you need...to know -
I did the same, but for some reason DVDDecrypter will not burn to my new NEC 16X, so I just burn the ISO with Nero and all works perfect. Never used the Shrink interfact to burn, didnt feel like having to set it up just to have a failure when the process I was using worked 100% of the time.Originally Posted by mats.hogberg
Andrew
question about dvd shrink
By marlo in forum Authoring (DVD)Replies: 5Last Post: 29th Aug 2010, 05:22 -
Hello I'm New & I Have A Question About DVD Shrink 3.2
By taffy1967 in forum Newbie / General discussionsReplies: 3Last Post: 4th May 2010, 05:28 -
question about DVD Shrink
By Bamahusker in forum DVD RippingReplies: 7Last Post: 1st Mar 2010, 21:48 -
DVD Shrink and Nero Recode question.
By siratfus in forum DVD RippingReplies: 8Last Post: 13th Jan 2010, 22:49 -
question regarding analyze in DVD Shrink
By Bamahusker in forum Newbie / General discussionsReplies: 2Last Post: 8th Jul 2007, 09:31
