i am trying to encode an avi file with ac3 audio and it gets to 50% and it stops..... can anybody tell me why this is happening and how to fix it.....
Have you tried encoding just the video and adding the AC3 in during the authoring stage? Assuming you are going to DVD. Using AC3 in the encoder may be the problem.
can you please explain how to do this , i have never done anything like this before.......
I suspect a problem with the file itself. I use XPress 3 all the time with the AC3 plugin on AVI with AC3 and no problem. Try running Virtualdub and extracting the audio and video and then add the video only to TMPGencXpress 3 and see hat happens. I'm betting on a corrupt avi, as tmpgenc products do really nice work but do not handle corrupt file gracefully as i would like. IOWs I;d like a better error message.
after i extracted the audio using virtual dub and i encode the video using tmpegnc express3 , how i add the audio.....
Replacement for TMPEGnc DVD Author for the Mac?
By The Monkees in forum MacReplies: 1Last Post: 24th Feb 2009, 14:36 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 04:35 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 12:39 -
AVI File Not Supported by TMPEGnc?
By The Monkees in forum Video ConversionReplies: 5Last Post: 3rd Feb 2008, 19:26 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 04:03
