I can't seem to find a straight answer to these...maybe you can help?
1) Does DVDFabDecrypter also copy the DTS audio to the HD?
(This DVD has AC3 2.0, AC3 5.1 and DTS)
2) Once I rip with DVDFabDecrypter to the HD...can I do a DL
burn and have it end up exactly like the original(having the layer
break in the same place)?
Or should I just rip with DVDDecrypter in ISO mode if I plan on
doing a DL backup?
I only done one DL backup(with DVDDecrypter - and successful) due to the prices on DL discs but I think I need to invest in a few DL discs for these two DVD's. The reason I chose DVDFabDecrypter(to DVD folders) to rip these was that I plan to make audio CD's of them as well.
Is DVDDecrypter in ISO Read/Write modes more accurate as far as
the layer break goes? Although the DVD's are new it appears that DVDDecrypter will have no problems working with them.
It took me a long time to get these DVD's and they barely arrived playable(the cases were crushed and the sleeves a bit torn) so I want
uncompressed identical DL backups. Sure I can re-rip them with DVDDecrypter any time I want but these questions just popped into my head....trying to save time and not give my HD's too much of a workout..![]()
Yes.
ripping with DVDFab Decrypter is basically the exact same as ripping with DVD Decrypter in File mode, except it bypasses the newer copy/ripping protections on a few newer dvd's that DVD Decrypter does not.
Few questions regarding LCD tv... that will lead to more questions :)
By ohlookyhere in forum DVB / IPTVReplies: 16Last Post: 15th Aug 2010, 16:50 -
Help needed to explain how DVDFabdecrypter or a similar programme work
By vladorlok in forum DVD RippingReplies: 6Last Post: 12th May 2010, 15:00 -
Powersupply questions and fan questions
By yoda313 in forum ComputerReplies: 39Last Post: 8th Sep 2008, 19:08 -
DVDFabdecrypter saves as .iso?
By magicfingers in forum Newbie / General discussionsReplies: 5Last Post: 7th Aug 2008, 09:01 -
DVDFabDecrypter Fails On German Deja Vu?
By hech54 in forum DVD RippingReplies: 3Last Post: 13th Oct 2007, 05:19
