Hi
I have an .avi file, with two audio. I also added the subtitle file-.srt, in Avimuxgui, but i cant see the subtitle, when i play it on my dvd player. What do i have to do, so i can switch the subtitle off and on?
Your player probably not supports subtitle streams in AVI. Not many do, AFAIK. Put the .srt as a separate file on the disc.
/Mats -
Will the .avi file then play with the .srt sub file? and should the .srt file have the same name as the .avi file?
How and what a "DVD" player does with an AVI and subtitles is entirely up to the specific make and model of player - it's by no means a standard, like Video DVD. Some players don't handle subs at all. Some who do, requires the subtitles file to have the same name as the AVI (except the extension), some (like mine) requires you to first select the subtitle file (any name) then the AVI, and will then play the selected AVI with the selected subs.
If all else fails - consult the manual.
/Mats -
How can i then "burn" the sub to the movie, so the sub are in the movie?
By reencoding, and adding the subs using a filter, something I only recommend as a last resort, since it will degrade the quality of the movie.
VirtualDub and the textsub filter is what to use.
Read on here
/Mats
Dazzle dvc100 w studio 12 does it capture AVI 1 or AVI 2 or DV-AVI
By st711 in forum Capturing and VCRReplies: 1Last Post: 10th Dec 2009, 18:30 -
avs (avi to avi) ends up out of sync ... winavi output file too big
By mandy in forum Video ConversionReplies: 1Last Post: 21st Aug 2009, 06:56 -
ffmpeg choppy audio from large avi but not small avi source file
By cybertheque in forum Capturing and VCRReplies: 9Last Post: 13th Oct 2008, 16:38 -
ffmegX v0.09w and converting avi videos into avi.ff.avi videos
By paddymick in forum ffmpegX general discussionReplies: 2Last Post: 3rd Nov 2007, 00:10 -
How To Split Single DV AVI file into Multiple DV AVI files using Time Stamp
By insysnet in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 23rd Aug 2007, 13:49
