  1. Hi to all. I'm making an AVI / DivX backup of a movie.
    I know that, selecting in VirtualDub Video__Select Range I can make two pieces having approximately the same size, but now I'm wondering another thing. Let's suppose I made an AVI 1400 MB in size and then I want to split it in two piecese aboout 700 MB each.
    How can I? Obviously the two pieces won't have te same length, and VirtualDub can split a file selecting a Range only by time/frames.
    If I had an AVI and I wished to split it in 2 of approx. the sane size, how could I?
    Please note: I want to use a free software, and I would just need a sort-of-trialware version which puts a sort of logo on the made parts. I would use that set to understand at which 'time' the '50% size' happens, and I would use the free (!) program VirtualDub to make the real cut.
  2. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    You'll not be that far off half file size if you split @ half time.
    /Mats
  3. Use VirtualDubMod -- it shows you the byte position within the file as well as running time and frame number.
    You can see the byte position in the regular version of VirtualDub too -- go to Options -> Preferences -> Timeline and add %B to the timeline spec. Unfortunately it shows the value in hex so it's a little harder to read.
  4. Nice, that suggestion on VirtualDubMod!! I never noticed it, before!!
    Thanks!!!
  5. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Another option would be to open the 1400MB AVI in virtualdubmod, video > Direct Stream Copy, then on the Save as dialog use the following:
    Should split at 700MB then
    If in doubt, Google it.
