Will a new system convert files faster? I know it seems obvious, but you never know til you ask.
Currently this is my system: Intel Pentium III 863MHz, 384mb RAM and WindowsXP.
I installed a DVD burner based on being told that it would work with this system, and it does. If I begin with already authored DVD files (a Video_TS folder) I can burn a DVD in a matter of minutes.
However, if I begin with an AVI file, it takes 24 hours or so to encode a feature length movie (an hour and a half or so) to MPEG2 using TPMGenc3.0Xpress. And it does so just fine. After the encoding is complete, it takes 45 minutes or so to actually burn the DVD (after adding chapters, etc using Nero).
Is this a normal time for file conversion using TPMGenc? Or will it actually be considerably faster with a new system? If this time is as good as it gets, there's no reason for me to get a new computer.
Results 1 to 11 of 11
Depends on how you define new. For someone with a 800 P3, a 1.0ghz Celeron in a new ATX Case may be considered a new system. You will definitely see an increase if you opt for a larger processor. If replacing your aging hard drive(recommended) you will also notice an increase in speed. You might also notice a jump by adding newer optical drives with faster read and writing speed specs.
The increased rate will be proportional to how you define "new system". -
Yes, it's normal. Yes, it will be considerably faster with a new system. 863 MHz is too lean IMO, considering todays standard system with 3.4 GHz CPU.
Encoding speed is almost linear to clock frequency, all other things equal, so a new box would cut your encoding time in 4. Even so, 8 hours is very long - about 1.5 - 2* video time is what I get for AVI to DVD specs MPG IIRC (long time since!) on my 3.2 GHz box.
What settings you use in TMPGEnc also makes a huge difference:
Never use highest motion search precision. It's insanely slow. 2nd or 3rd best is good enough.
Avoid filters in TMPGEnc - filter with VirtualDub (if you have to) and frameserve to TMPGEnc.
There are faster encoders than TMPGEnc...
/Mats -
Originally Posted by mats.hogberg
Originally Posted by ibzomie
You'll see a vast improvement..... -
Originally Posted by ROF
I admit that the development seems to have slowed down a little these last years, so maybe I can stick with my box a little longer this time!
/Mats -
Six months after that I got a capture card that captured directly to mpeg. That saved me another 5-1/2 hours for every 2 hours of video I was converting.
The 45 minutes it's taking to actually burn the DVD is more likely caused by the disks you're using- I'd guess they're probably 1X. -
I know Videoguys has an article about building for under $1000.
http://www.videoguys.com/DIY.html
Nothing about under $500. -
Chaintech SK8T800 Socket 754 Barebone Kit / AMD Sempron 64 2500+ / 128MB Video Card / 512MB DDR PC3200 / ATX Mid-Tower Case with 400 Watt PS / Keyboard / Mouse for $189.00
Just add HDD and Burner.
BTW, this machine is faster than a 2.9Ghz Celeron on video and gaming apps. The case is clean and the thing I find I like the more I build with it is that when the power is on there are two green lights that look like alien eyes on either side of the bright silver power button, but when the hard drive is being accessed a red crescent shaped light appears to blink beneath the power button giving the appearance of a smiling alien. Pretty neat and built for under $300.
For under $1000 I can put together something much more impressive.
why does Avidemux play back files faster or slower
By mukluk909 in forum EditingReplies: 1Last Post: 2nd May 2011, 12:26 -
I have a 64bit system, to encode files do i need 64 bit codecs?
By shadowofanubis6 in forum Newbie / General discussionsReplies: 5Last Post: 1st Mar 2010, 10:24 -
System Requirements to Rip/Convert Blu Ray
By minerva.thegift in forum Blu-ray RippingReplies: 5Last Post: 22nd Sep 2009, 23:16 -
Computer question, what makes them encode faster, unrar faster etc.?
By willhenderson in forum ComputerReplies: 5Last Post: 30th Sep 2008, 22:21 -
Minimum system requirements to play 720p files?
By ukb007 in forum Newbie / General discussionsReplies: 11Last Post: 21st May 2008, 13:36
