hey guys even though i am not using component video cables i see that when enabling the progressive scan option on my CH-DVR 1200.
the picture quality takes a noticable increase in picture quality the overall image quality is sharper and smoother than with the option set to off..
i got a question regarding that. can a dvd recorder record with the progressive scan enabled or is that just for video out only??
the reason why i ask is because i have noticed when playing back the dvd+rw on a standard dvd player the improvement is very evident....
i am pretty sure someone knows the answer to my question if it helps i am recording from digital cables toon disney channel..
Cannot record in progressive.
Doesn't work that way.
That is for playback only and even then should only be used when you have a progressive DVD as a source.
Any recordings you make would be interlaced.
Will a progressive scan MPEG2 work on all DVD Players?
By jnms in forum Authoring (DVD)Replies: 29Last Post: 30th Oct 2011, 17:22 -
BD/DVD Interlace vs Progressive Scan: Which is better?
By Bonie81 in forum Newbie / General discussionsReplies: 9Last Post: 2nd Dec 2010, 07:01 -
Are there progressive scan DVD discs??
By seekt in forum DVD RippingReplies: 33Last Post: 21st Oct 2009, 13:52 -
PAL Camcorder with Progressive Scan Mode
By ropdoh in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 4th Jul 2007, 08:27 -
Creating DVD for progressive scan DVDplayer/TV
By halsboss in forum Authoring (DVD)Replies: 1Last Post: 18th May 2007, 20:58
