I'm using Final Cut Studio to make short movies for DVD. I'm sure this is a stupid question, but here I go:
When I finish my DVD and play it back through my DVD player on a TV set, almost invariably the volume of the sound of the music track I placed to play on the menu is much louder than the sound volume on the audio tracks of the movie itself. When the menu background music begins to play, the volume is too loud and I have to turn down the TV volume. Then I have to turn the volume way up when the movie itself starts to play. This is quite annoying. I'm sure there must be a simple solution.
The problem seems to occur when I drag a music file from iTunes and drop it into the DVD's menu (in DVDSP) to play in the background. This music seems to have too high a volume compared with the volume on the movie itself. There doesn't appear to be any way to modify the volume on the background audio once it is imported into the menu. Do I need to adjust the volume of the menu background music in another software before dragging and dropping it in DVDSP?
Thanks,
John
Results 1 to 1 of 1
Background audio/music
By web_smurf in forum Authoring (DVD)Replies: 3Last Post: 14th Sep 2011, 03:44 -
TMPGENc Authoring Works 4: Menu crashes after I add background music
By silentmachine in forum Authoring (DVD)Replies: 2Last Post: 11th Aug 2011, 16:32 -
Can anyone recomend audio recording software for background music?
By bweath in forum AudioReplies: 4Last Post: 18th Jun 2010, 06:12 -
Adding audio as background music whilst listening to the main sound
By Mrwoo1234 in forum AudioReplies: 3Last Post: 29th Dec 2007, 10:30 -
legality of using copyrighted music as menu audio background
By nbi in forum Authoring (DVD)Replies: 3Last Post: 20th Nov 2007, 04:14
