I have a problems with many .avi that I converted on ffmpegX, using the MPEG 4 [.AVI] encoder, with audio Passtrough to preserve AC3 and loading subtitles in spanish, after that I got an .avi file with Harcoded Subtitles as I wished, and learned on this forum.
But the problems starts here:
I tried several times to burn or make a disc image of 3 of this .avi on a DVD with Toast 7; using the create a DVD option on video tab. It starts encoding the first one and Toast quits by itself, says something like Toast has unexpectedly quit you want to reopen...
I tried to do the process on iDVD with just 2 .avi but after a while it quits and says something similar, iDVD has unexpectedly quit...
So I wonder if the problem is with the files tha I encoded, because the original files were able to be Toasted; or I have a system problem, or to burn a DVD with .avi I should use other encoder? Remeber that I want to burn the subtitles.
Know what may be wrong?
Cheers lads,
M.
Results 1 to 1 of 1
Can't install binaries for ffmpegX 0.0.9y
By kostas1969 in forum ffmpegX general discussionReplies: 2Last Post: 21st Feb 2012, 13:14 -
Incorrect Timing on DVD burn: H.264 mp4->ffmpegx->Toast or Burn
By DirectorSG in forum MacReplies: 2Last Post: 29th Jan 2012, 13:42 -
FFMPEGX problem with binaries
By tyedyetc in forum ffmpegX general discussionReplies: 4Last Post: 19th Mar 2009, 15:24 -
Can't install ffmpegx binaries on Macbook Pro OSX 10.4.11
By camelsauce in forum ffmpegX general discussionReplies: 3Last Post: 7th Aug 2008, 13:49 -
ffmpegX additional binaries - where the h*ll should they be?!
By nickelbump in forum ffmpegX general discussionReplies: 10Last Post: 31st Dec 2007, 21:12
