I just bought this card
http://www.hauppauge.com/pages/products/data_goplus.html
from friday's rebate sales for $19.99, which I thought was a pretty good deal. I have yet to install it, since my computer is at school, but I was trying to figure out if it would be possible to capture video from a camcorder to transfer to DVD?
I was thinking I would connect the camcorder to my vcr using yellow/red/white connections, and then connect the coax-out to my wintv card. Would this produce decent results? My camcorder is an older model which uses 8mm tapes, so the picture isn't too sharp to begin with.
I tried capturing direct to dvd using my liteon 5005 dvd recorder, but it was too much of a hassle re-ripping the dvd, converting to avi to edit, and then re-converting to dvd. Also, for video over 1 hour the liteon didn't produce very high quality picture.
-Yar, matey!-
Those are the only results you can get since that card doesn't have svideo or rca input jacks. It should be decent enough. I use my wintv pvr250 and have captured from a analog 8mm sony camcorder with good results but the pvr250 has svideo in.
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
I got the card, I set it up and installed all the software, the television quality is decent (my school has standard analog cable).
My problem now is that it won't record. I sent an email to their tech support, but I'm still waiting for a reply. When I try to record, it gives me some error about my MPEG audio encoder, even when I choose divx or pure avi. I don't understand, I have all the codecs I need, and I installed everything needed from the cd...I even updated the software from the website.
Anyone have this problem?-Yar, matey!- -
Fixed this myself, too (in case someone in the future has the same problem).
You have to make sure the audio source is set to your sound card, not your modem! So simple, yet took me so much time...-Yar, matey!-
Capture card or Video card w/ capture tool
By joelson in forum Newbie / General discussionsReplies: 1Last Post: 11th May 2009, 10:45 -
Hauppague WinTV-HVR-1600 vs Avermedia capture card with SAA7130 chip
By johnnyquid in forum Capturing and VCRReplies: 1Last Post: 23rd Mar 2008, 18:29 -
Hauppauge WinTV 2Go capture card was Kworld DVD Maker USB 2.0
By Vampire74 in forum Capturing and VCRReplies: 4Last Post: 19th Jan 2008, 09:59 -
Unable to capture from camcorder with WinTV-PVR 250 card and and WinTV2000
By forestial in forum Capturing and VCRReplies: 1Last Post: 29th Dec 2007, 19:00 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 17:15
