While trying to merge 2 divx/avi files I encountered this error
Virtualdub has detected an improper VBR audio encoding in the source AVI file and will rewrite the audio header with standard CBR values during processing for better compatibility. This may induce up to 0ms of skew from the video stream. If this is unacceptable, decompress the entire audio stream to an uncompressed WAV file and recompress with a constant bitrate encoder (bitrate: 128 +/- 0.1 kpbs)
I don't really use virtual dub that much. Anyone know of this problem or how to fix.
Thanx All.
I reject your reality
and substitute my own.
- Adam Savage -
- Mythbusters - -
No problem. Just hit "No". And it's better if you use VirtualDubMod for the job (maybe you are already).
error message when adding SSA. file to virtual dub
By fredsieg1937 in forum SubtitleReplies: 1Last Post: 24th Sep 2009, 20:53 -
virtual dub "non-zero start position" error
By DaneClark in forum EditingReplies: 1Last Post: 17th Aug 2009, 20:24 -
Virtual dub
By santolina in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jul 2009, 13:48 -
Error when trying to compress with Virtual Dub
By las7h0p3 in forum Video ConversionReplies: 2Last Post: 7th Oct 2008, 13:39 -
Auto Gordian Knot error issued by Virtual Dub
By loninappleton in forum Video ConversionReplies: 10Last Post: 30th Apr 2008, 11:56
