Hi,
OK, I'm a total noob so be gentle, it's my first time.
I'm trying to make a nice DVD of 6 episodes of a show. I have each episode as a .avi file.
I tried using Ulead DVD Factory 4 & it seems to do all I need apart from give me a template with 6 'episode picks'. All the templates they have seem to use 4 max. I was going to change the background & music & stuff anyway but wanted to start with 6 buttons. I can't believe you can't just make new ones in the package.
So, I tried Photoimpact as recommended. I duplicate the buttons, save the files, open it in DVD Factory & it crashes.
I did look at using TMPGEnc DVD but it keeps coming up with errors about the video format, fps & size etc. I don't want to get into that too much but the DVD factory can handle the file types no problem, apparently.
Is there a very userfriendly package out there where I can make a decent menu page (with music & video playing in the episode button areas etc), it handles converting all sorts of file types itself & I can easily get an output to burn?
I know there must be one, I can't believe this is so hard, I know it's my ignorance that is the problem.
Thanks for any help,
James
Results 1 to 1 of 1
TMPGEnc Authoring Works 5 Version & HD-PVR Question
By TBoneit in forum Authoring (Blu-ray)Replies: 25Last Post: 18th Nov 2015, 18:20 -
TMPGEnc Authoring Works 4 & MKV
By Teac23 in forum Video ConversionReplies: 1Last Post: 14th Aug 2010, 15:29 -
What is the different between TMPGEnc Authoring Works 4 & TMPGEnc 4.0 XPres
By c1steady in forum Newbie / General discussionsReplies: 0Last Post: 28th Apr 2010, 22:32 -
Best authoring program & how do I take footage off a dvd to use on anot
By charlesb in forum Authoring (DVD)Replies: 7Last Post: 8th May 2008, 06:09 -
DVD authoring and encoding on TMPG and Ulead
By bellyting in forum Newbie / General discussionsReplies: 4Last Post: 29th Jun 2007, 17:53
