I have about a 10 minute clip in asf format that is taking forever to convert to mpeg. Time says 56 hrs has been running now for 11. I am using a 550 AMD with 503 ram. Is this the only encoder that can do asf files? I loaded the PAL template but if I change all the settings would the template loaded make much of a difference. I seen an earlier post about "a template that works for me" Should there be an icon next to the template showing windows understands?If a couple minute clip takes this long how long would a real movie take?
Results 1 to 1 of 1
Problem With TMPGEnc
By Halibut72 in forum Video ConversionReplies: 2Last Post: 1st Oct 2008, 12:38 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
Problem with TMPGEnc
By The Monkees in forum Video ConversionReplies: 2Last Post: 1st Nov 2007, 16:58 -
TMPGEnc Problem
By djkevyb in forum Newbie / General discussionsReplies: 3Last Post: 27th Sep 2007, 16:46 -
TMPGEnc Problem !!!!!!!!!!!!!
By homantam in forum Newbie / General discussionsReplies: 2Last Post: 10th Sep 2007, 18:56
