Has anyone had any luck determining what DVD+/-R media is compatible with the Kawasaki PVS10921 9" Portable DVD player? Must be a fairly new product because I've been unable to locate much info on it on the internet.
So far, I've found the following media to be incompatible:
TDK DVD+R 8x
Memorex DVD+R 8x
Memorex DVD+R 4x
If it matters, the burning software I'm using is Nero 6.
Here's the link to the manufacturer's website:
http://www.18002526123.com/findit/pvs10921top.htm
If anyone knows what type of media is compatible, I'd appreciate the info. Thanks!
