  1. I recently made a DVD but I messed up a lot of the menu stuff and it looks ridiculous. I want to start over but I lost the original files (burned old files to a data disc and now it doesn't work). Is it possible to get just the video files from the DVD? I hope there is a wonder program out there that can do this. Can anybody help me? Thanks!
  2. Member waheed's Avatar
    Jul 2003
    Manchester, UK
    ISOBuster can recover files from a DVD.
  3. Member thevoelk's Avatar
    Sep 2004
    Forest Hill, MD
    You can probably do it with DVD Decrypter. Select File Mode and just the main movie.
  4. Retired from video stuff MackemX's Avatar
    Nov 2002
    VIP Lounge
    I'd recommend Isobuster also
    if you use DVDDecrypter make sure you adjust the check error settings to ignore it automatically after so many tries
    there is another commercial program but I can't recall the name (forum search won't work ATM) but it's got rescue in the name
  5. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    Yep, i have used IsoBuster quite a few times to get dvd files from a disc that absolutely nothing else would! dvd-ram disc's, dvd disc's that could not be finalized and would not even be read by anything else as having files on it, the drive would even show it as an empty disc, open up IsoBuster, there thay are, ect. ect. ect.
    Great tool!!!
    You too huh ? i thought it was just me thinking the site was acting a little weird :P
  6. Banned
    Jun 2004
    Seem to be having problems getting replies to post, and the main page even after refreshing shows this thread as only having 2 replies
  7. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    I don't see anywhere where the OP mentions that the disc is unreadable; just that he buggered up the menu and needs to original MPEG files back. If this is the only problem, then VOB2MPG, TMPGEnc DVD Author, Rejig or VOBEdit can all help, with the first two creating MPEG files, whilst the latter two demux back to elementary streams.
    If in doubt, Google it.
  8. Thanks you so much! And a special thanks to JimMalenko. He's answered 99% of all the questions I've posted! Thanks ALL!
