Im Using VSO DivxToDVD and adding Subs to the inserted Video file, but after making the DvD the Subtitle are not on the DvD and the Toggle Subs on and Off dont work?
what could be going worng?
or what othere program could i use to make a straight forward DvD maker and add subs?
tried to play the dvd on your computer with a software dvd player?
what kind of subtitles? srt etc? -
The Subs work with WinDvD but not with wmpc or my 4 DvD players in the house :S
i made these Pics to help, if you see any thing wrong please say ^^
I think my Problem mite be to do with the first page "Page Code"
im trying to Get my Subs on to DvD option or Perment, it dosnt need a menu.
i tried using TMPGEnc Plus 2.5 and Seperating the AVI to mv2 and AC3 but the sound didnt work but there subs wer on there permently..
so i tried ripping the sound to wav and converting it to AC3 the sound worked in the file .ac3 but when i tried using DvDLab Pro the sound stop working on the fisnished DvD.. so i left that and tried VOS DivXToDVD and the subs dont work at all on my DvD Players.
all i need is a simple way to get Subs Permeny or option, with or without a menu. if my problem gets fixed i'll even donate to the webpage
It seems to me that you are not using the most recent version of the software.
What version are you using?
Go to VSO DivXToDVD web page and download new version first.
I suggest that you leave ALL options at default automatic settings.
When you do that, try to convert the same file with subtitles and report a result.
The subtitle has to be in .srt format.
Do you use any subtitle software to check for errors in your subtitle file? -
Iv downloaded the newest version, what software would you recommend to check my subtitles?
or you can download it
simplier maybe? (the subs that is)
http://www.rapidsharing.com/8a3b421908e25f3adb257336a4eb392a
[Edit] ohh sorry, yes the subs are in srt -
I use 2 subtitle software:
Subtitle Workshop
DIVXland Media Subtitler
Subtitle Workshop has an excellent help file and many automatic features. -
I've checked that subtitle file.
Yes, it seems that it is in .srt format.
A number of lines are way too long, up to 80 characters per line, so the subtitle definetely needs some editing.
You could try to instal DIVXland Media Subtitler, open that subtitle file, let the program to automatically fix it with default settings. Then save as new file and see if it works.
Adding subs.
By Ytrix in forum SubtitleReplies: 2Last Post: 21st Oct 2010, 11:39 -
Adding additional subs
By Wan Dat Ting in forum MacReplies: 1Last Post: 26th Oct 2008, 02:14 -
Previewing and adding subs
By lucho89 in forum ffmpegX general discussionReplies: 1Last Post: 2nd Aug 2008, 07:28 -
Adding Subs
By Russo in forum Newbie / General discussionsReplies: 1Last Post: 2nd Dec 2007, 20:45 -
adding subs prob
By SilverDales in forum SubtitleReplies: 3Last Post: 20th May 2007, 09:29
