DVD Decrypter came up with a redundency error, so I used DVDFab Decrypter, but DVD Shrink says that there's invalid data in the first VOB. My ultimate goal is to create an xvid for playback over my xbox.
Has anyone else gotten this error & if so, what did you do to fix it?
Results 1 to 17 of 17
I had no problem ripping war of the worlds (region 2 uk pal) with dvd decrypter ... i haven't done the shrink bit yet tho ... i will do it later and let you know the result
Ok i've just run it thru dvd shrink (full disk) and had no problems .... maybe you have a faulty disk
well if you get redundency error don't it normally means the dvd is dirty?
How Big A Boy Are Ya? -
Originally Posted by psx_pirate
Another member is reporting a similiar problem here:
https://www.videohelp.com/forum/viewtopic.php?t=285602
Maybe these guys have got hold of one of the DVDs from a faulty batch? -
Originally Posted by Topher5000
You can buy them from most electrical stores.
I got mine with a DVD/CD Lens Cleaning kit. It comes with a lint-free disc cleaning brush aswell. -
I've cleaned many discs with a little dish soap and warm water,wipe with kleenex tissue so it soesn't scratch.never had a problem.I'm sure someone will take me to task with my method,but it's easy and it works.
bmiller,ont.canada -
Yep,
Done it for years!! under warm running water and a little dish soap and wash it with my fingers lightly & pat dry 8) makes those baby's shine :P
Oh yeah, backed up region 1 WOTW with just DVD Decrypter & DVD Shrink, Zero issues!! watched the BU wensday night and looked great -
how much compression did it take to put on a single layer dvd?
I also had no problem using DVDDecrypter then DVDShrink.
Originally Posted by ghoster -
I clean disks using isopropyl alcohol 91% and a mirror and glass cleaning cloth. Isopropyl alcohol is available in grocrey store and drug stores, just make sure to get a 90% or higher bottle. The stores will have like a 60% isopropyl alcohol and it will leave streaks on the disk. I also believe a old tee shirt would make a good cloth. And a fifty cents spray bottle and there you go.
I've tried ripping two copies now of War of the Worlds disc 2, using both of the latest updates to Dvd Decrypter and DvdFab Decrypter.
I can rip it to the hard drive, but when I use my burning software, Roxio 8, it's not reading the VOB files.
I've tried burning it also with Nero, but it states that the project may not be readable.
With Nero Recode I get the message: Failed to open the file VTS_05_0.IFO. There are no more files.
Any ideas? -
No problem using dvddecrypter , vobedit , besweet , ifoedit , dvdshrink , imagetools .
1: rip entire dvd to hd .
2: Strip down to video and audio asset's .
3: Re-encode ac3 to lower bitrate .
4: Regenerate vob title .
5: Shink just slightly under 4.3gig .
6: burn .
Everybody enjoy's it .. stick it in and go ... the way I like them .
As for disc error's .
Washing the plastic carrier face will remove any trace's of grime that might cause read issue's .
Use cd scratch remover fluid : http://www.wipeoutcdrepair.com/cgi-local/store/commerce.cgi?product=WIPEOUT
I personally demonstrated how serious this product is as compared to other's ... nothing beat's it for value .
1: Nail scratched half way through plastic media carrier .
2: Fine sand paper to remove most of deep scratch .
3: Wipeout to finish scratch .
4: Smoker's tooth paste for the final clean .
Played 100% .
Be aware , the disc could be produced on inferior media ... there could be a small bump on the written side .. there enough to prevent copying ...
Hole's are a no no (the one in the middle is acceptable ... lol) .
Want worlds easiest workflow with 20 .movfiles h264 and a soundtrackreplace
By iannz in forum EditingReplies: 1Last Post: 3rd Feb 2011, 11:12 -
RipIt4Me Having problems backing up Avatar?
By diggingeagle in forum Newbie / General discussionsReplies: 2Last Post: 18th Aug 2010, 07:12 -
Problems backing up Transformers 2009
By Captain315 in forum DVD RippingReplies: 18Last Post: 30th Oct 2009, 23:43 -
Stargate Worlds Beta testing underway
By yoda313 in forum Off topicReplies: 4Last Post: 25th Jul 2008, 17:35 -
Sony PlayStation 3 - worlds fastest computer
By joepic in forum ComputerReplies: 19Last Post: 23rd Jul 2008, 01:00
