How do I convert a .mkv file with h.264 video, AC3 5.1 audio and English Subtitles to .vob files to be burnt to a DVD-R ?
I have tried VSO DivXtoDVD and AVI2DVD, both dont work.
AVI2DVD gives a floating point error and DivXtoDVD freezes on 6.8%
And by the way - they say that you can use DVDsanta - but it doesn't work for me. Santa crashes.
http://www.matroska.org/technical/guides/dvd/index.html -
I dont want to convert it to AVI, I want to convert it directly to DVD.
If it accepts input via dshow then it should accept anything that you can play via dshow which will include mkv files if you have the correct filters installed.
To playback mkv files you need a splitter, plus decoders for contained streams and a subtitle render if it has subs. Basically there are two splitters; gabest's and haali's, numerous decoders depending on the streams and for subs you have directvobsub (VSFilter) and ffdhow.
Some filters might not work well with DVDSanta or vice versa.
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 11:19 -
How to play MKV, MKV to AVI, MKV to DVD, MKV to Xbox 360 or Playstation 3
By Baldrick in forum Video ConversionReplies: 2Last Post: 8th Mar 2012, 02:45 -
How to convert mkv to ps3 viewable format maintaining mkv subs in new file?
By shuyinliquid in forum Video ConversionReplies: 2Last Post: 14th Dec 2009, 01:17 -
mkv question... many mkv files (with subs) into 1 mkv?
By 0okami in forum EditingReplies: 1Last Post: 24th Oct 2009, 00:45 -
DVD to MKV - MKV to VOB/DVD?
By pavista in forum Video ConversionReplies: 5Last Post: 14th Jun 2009, 06:31
