Hi I have 7800GTX with vivo and im looking for program to capture video true the card (i want the best quality in the video).
The manufacturer of the card usually provides software for that. Generally it's usually you best choice for capture.
Yes i have the program from the manufacturer but the files that i capture are not in good quality, maybe the conection is wrong ?
i conected the composite cable to the tv and s-video to the card. -
I'm confused? You using outputs from your TV? S-video would be for the video, you would only need the composite for audio.
There's many reasons it can look bad, you'll have to provide more info such as the card manufacturer info, what preset your using to capture with etc. -
The cable im using for the video is from one side composite and from the other s-video, the composite is conected to the tv and the s-video to the card.
why does my ATI VIVO quality suck so bad
By bacobits in forum Capturing and VCRReplies: 3Last Post: 2nd Jan 2008, 20:22 -
Finding vivo on the newer video cards
By Steen4 in forum Capturing and VCRReplies: 6Last Post: 11th Nov 2007, 23:56 -
Capturing VHS by using VIVO
By Filsps in forum Capturing and VCRReplies: 0Last Post: 15th Sep 2007, 14:17 -
No VIVO support in Vista???
By drinklime in forum Capturing and VCRReplies: 13Last Post: 11th Sep 2007, 14:43 -
Anyone using MMC with X800XL VIVO-only (no TV tuner or AIW) for capture?
By palouse in forum Capturing and VCRReplies: 4Last Post: 15th Aug 2007, 02:28
