    I've been backing up some of my stuff and in the process came to my DL movies (most of my DVDs are of old B&W classics, so many of them are not DL). I read through a bunch of posts and decided to try CloneDVD2 as the means to split a DL into two DVD5 sections, keeping the menus on each one. I did this becuase I have so many single layer blanks that right now it seems more practical to just do it that way. I don't believe in compressing any movie backups.
    So I used CloneDVD2 to make two DVD5s, but when I looked at the IFO files I still saw a layer break indicator. If I burn a single layer disk with these files (the total of which is less than 4.4GB) what will happen to the indicated layer break? Will it hurt if I leave it in the IFO file? Is there a way to remove it cleanly if I have to?
    Bump... no response yet.
  3. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    I'm sure I've looked at IFOs from DVDShrink in IFOEdit that have left the layer break indicator in. Hasn't seemed to affect any of my backups.
    If in doubt, Google it.
