does anyone have a guide for correctly setting up the xvid codec for best quality? my source material is very good but when i convert to xvid i see a lot of compression artifacts.
Hi-
If you're getting compression artifacts, then it sounds to me as if your bitrate is too low for the resolution, or the resolution is too high for the bitrate. However, about the best explanation I've run across for XviD in general, and the settings specifically, is Crusty's:
http://ronald.vslcatena.nl/docs/xvidfaq.html
More information here:
http://forum.doom9.org/showthread.php?t=16935 -
http://www.google.com.au/search?hl=en&q=xvid+configuration&meta=
First link.
Ahhhhhhh google.If in doubt, Google it.
What is divx and xvid codec?
By Azrail in forum Newbie / General discussionsReplies: 4Last Post: 5th Oct 2010, 21:31 -
How do I use the Xvid codec without really installing it?
By KneeRow in forum Software PlayingReplies: 1Last Post: 18th Apr 2010, 15:27 -
DivX and xVid codec
By cheerful in forum Software PlayingReplies: 9Last Post: 10th Jan 2010, 21:55 -
Intermediate codec and xvid question, and xvid to wmv.
By ^xRun^ in forum Video ConversionReplies: 9Last Post: 22nd Jul 2008, 17:13 -
Weird I don't have XviD or DivX codec installed but I can see Xvid movies
By Talayero in forum Software PlayingReplies: 4Last Post: 5th Jun 2008, 11:47
