is there a way to fix video files that has out of sync audio? i have a rmvb format video that is pretty badly out of sync. The audio plays slower than the video..
any programs i can use?
thanks
Results 1 to 11 of 11
Sure, lots of ways. Do a forum search for 'sync problems' and you should see quite a few. Check the length of the audio and video and see what they are. If the lengths are different, you adjust one or the other.
ok thanks
i found a tutorial for fixing sync. it said i needed to convert to mpeg format. Do you know a program that can fix sync problems that supports RealMedia files? -
yes, this is the question i want to ask too.
is there anyway to fix the offsynced audio of an rmvb file not changing its format (i want to keep the rmvb format) -
... move on to more standard and popular codecs like DivX or XVid. Life will be better
so, how do you resync the audio file after extract it?
it's only some parts, not the whole video is out of synced?(i think i have to do it manually but how do i do it?)
i coudn't find any guide about this -
It's not going to be easy.
Two programs that might help are Hypercube Time Stretcher and SyncView. They can help adjust the sync alignment. Otherwise it is just often trial and error.
If the video was composed of clips that have differing sync problems, you would have to separate those out and adjust the sync individually for each, then put the audio back in and rejoin the clips together.
This can be a lot of work. Usually unless I desperately need the video, I just delete it and move on.
There are two main types of sync problems. In one the audio is longer or shorter than the video and you have to stretch it or shorten it. The audio would drift out of sync as the video plays.
The other type is when the audio starts too early or too late. You can add a delay or reduce the existing delay to try to correct this. The audio would stay at the same unsynced interval the whole time.
This is complicated by RM as there are few editors that can handle the video format easily. -
I had this problem for months.
I finally fixed it by doing two things:
1.) I eliminated unnecessary/redundant codecs (I now only have a VLC codec/player and a vista codec/decoder.
2.) I relocated the position of my computer to ensure that it did not get too hot or overheat.
My problem has been resolved.
I'm sure that over the years, specific solutions will change with changes in technologies; but, it is often the case that problems, breakdowns, and questions remain the same. Perhaps, six years from now no one will know what a codec pack is; but, they might still understand that too many mechanisms working on the same task may, and often do, confuse and disrupt smooth operations, if they don't, in fact, cancel each other out.
Brain dead, walking dead, e-dead ... we might all benefit from a wake-up call.
Fixing sound sync issues in a mkv file
By Psykro in forum EditingReplies: 12Last Post: 20th Dec 2014, 12:31 -
Fixing / Determining Audio Sync Issues With Only Some DVDs
By TheNut in forum DVD RippingReplies: 5Last Post: 12th Dec 2009, 18:47 -
Fixing audio sync issues when using GOTSent to convert MKV to MP4
By darrklight1138 in forum Newbie / General discussionsReplies: 1Last Post: 20th Apr 2009, 07:56 -
Fixing Slow and out of sync .mkv file/video
By vanleeuwen in forum Blu-ray RippingReplies: 2Last Post: 18th Dec 2008, 08:26
