if my dvd player can't read vcd's can it read svcd's?
Sadly my crystal ball is away being polished so I can't see which player you have. You'll have to tell us the make and model.
He's a liar and a murderer, and I say that with all due respect. -
svcd is mpeg2 but its encoded at a lower bitrate (in the 2000 range) and at a resolution at 480x480 so its not compatible with dvd. Plus the audio is 44.1 khz not 48khz like dvd.
Chances are if it doesn't do vcd it won't do svcd.
EDIT
https://www.videohelp.com/dvdplayers?DVDname=apex+ad+1225+&Submit=Search&Search=Search&...y=Name&hits=25
According to user reports it actually CAN play both.
Have you tried using rewritable cds instead of cdr's??? Some players won't read recordables but CAN read rewritables. Try it out.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
It's possible, but certainly history shows that VCD seems to be the most widely supported, with SVCD a distant 2nd. In my experience, anyway. So there's usually a much greater chance that it supports just VCD (and not SVCD) than just SVCD (and not VCD). Not to say that it can't, though.Originally Posted by arredja
As yoda mentioned, users have reported successful playback of (X)(S)VCDs without too many problems, which would indicate that perhaps your encoding or authoring processes for VCD may not be correct ATM. Either that or your player just doesn't like the CD media you're using.If in doubt, Google it.
VCD to DVD (not SVCD)
By noyou in forum SVCD2DVD & VOB2MPGReplies: 20Last Post: 19th May 2009, 17:56 -
How to make a VCD/SVCD with CD Audio (CDDA)
By Baldrick in forum User guidesReplies: 74Last Post: 24th Dec 2007, 19:37 -
Beeping on vcd/svcd
By mgdt in forum Newbie / General discussionsReplies: 5Last Post: 20th Dec 2007, 11:56 -
avi to vcd/svcd
By neynme in forum DVD RippingReplies: 7Last Post: 26th Aug 2007, 21:25 -
How to copy-protect a VCD/SVCD v2.0
By Sine29 in forum User guidesReplies: 23Last Post: 20th Jul 2007, 11:27
