  1. How do i get my upload Ratio up
    i have a routor heres a pic
    DI-604
    USA
    Have you been to a site like this or similar to do some speed tests? You ISP may be limiting your uploads, though probably not that much.http://www.dslreports.com/tools
    Also you might want to change your port numbers if you are using the default ones. Some ISPs block them.
    If the speed tests come back slow, disconnect your router temporarily and check the speed directly from the modem. That will tell you if the router is a problem. I use a DI-704 and my only up limit is from the ISP. I have to slow down the uploads as they will exceed the downloads in speed if I don't.
    The type of software you are using may also need some fine tuning. Check their site for tips.
  3. Originally Posted by redwudz
    ill try it out. ill post back if i run into any problems thanks
