I ripped Madagascar to my HD with AnyDVD and DVD Decrypter no problem with ISO setting. Shrunk it with CloneDVD2 and burned it with a Lite-On Model SOHW-1673S with the most current firmware and it appeared to have worked just fine. Tried to play it in a stand alone DVD player and it would not play. Used DVDinfo to find out the media code on the media and it could not find any code and told me the DVD was blank. Installed new Lite-On SOHW-1693S and most current firmware and tried it again same problem. When I look at the media code before burning it states that it is TYG02 after burn it cannot find media code. On another computer that I did not rip Madagascar to I have had no problem with any burns from the same spindle of Taiyo Yudens DVD-R's 8x media. I am at number 30 on the spindle right now and have had 9 bad burns so far on that problem machine not in a row but random. Tried burning with CloneDVD2, VSO CopyToDVD, Sonic RecordNow! Deluxe, DVD Decrypter same problem. Anyone have a similar problem? Suggestions?
the men in black are coming to get you.
backing up mediocre animated movies is a crime.
but seriously,get the latest dvdfab decrypter and run the latest anydvd in the background when you do that.
for new releases,unless you want to make your own.psl file for dvddecrypter,then its like flogging a dead horse
good in its day,but now just really an image burning software.LifeStudies 1.01 - The Angle Of The Dangle Is Indirectly Proportionate To The Heat Of The Beat,Provided The Mass Of The Ass Is Constant.
Panasonic DVD & USB & SD Card Slot Problem
By Tim Sage in forum DVD & Blu-ray RecordersReplies: 1Last Post: 20th Mar 2011, 19:23 -
Converting LIT to PDF Adobe (Ebook)
By Teac23 in forum ComputerReplies: 0Last Post: 30th Mar 2010, 12:49 -
unwanted Windows Explorer popup after ImgBurn 2.5.1.0 burns & verifies
By JohnnyBob in forum Newbie / General discussionsReplies: 0Last Post: 26th Mar 2010, 18:27 -
power LED is not lit, computer's working
By cL0N31 in forum ComputerReplies: 9Last Post: 3rd Sep 2008, 14:16
