Hello i have been trying to find some help on adding subtitles to a vcd (it really a kvcd) , Anyway all the guides i could find are for using an avi as source and then econde to mpeg . But if i already have an mpeg source ( bin/cue files or the dat file) , whats is the fastest way to add subtitles ?,
Something like mpeg1 to mpeg1+subs (switchable or not )
https://www.videohelp.com/forum/viewtopic.php?t=272736
and frameserve to an encoder
https://www.videohelp.com/virtualdubframeserve
or
use avisynth with textsub filter and frameserve to an encoder.
or
if you want switchable that works on your computer just use a software player that can load subs or use ffdshow,vobsub. it wont work on vcd. -
Sorry for the double post, i didnt know wich sub-forum was the correct one, im looking to play this on an standalone dvd player
Is there anyway to add the subtitles without re-encoding ? ( my computer isnt really that fast :S , will take long long time )
ok thanks
Oh and also in the computer i loaded the dat file and the subs using mplayer for windows and it works like a charm.
Adding subs.
By Ytrix in forum SubtitleReplies: 2Last Post: 21st Oct 2010, 11:39 -
Adding Subs to Avi
By ill_kuma in forum SubtitleReplies: 7Last Post: 9th Feb 2009, 20:02 -
Adding subs to VOB?
By Jens Thomsen in forum ffmpegX general discussionReplies: 8Last Post: 19th Jan 2009, 18:05 -
Previewing and adding subs
By lucho89 in forum ffmpegX general discussionReplies: 1Last Post: 2nd Aug 2008, 07:28 -
Adding Subs
By Russo in forum Newbie / General discussionsReplies: 1Last Post: 2nd Dec 2007, 20:45
