    Apr 2003
    I am trying to convert a DVD to Divx using this guide https://www.videohelp.com/sefy/?id=direct8.html when i get to the final stage a press go for it i get a window pop up saying 'Dont save the divx un a directory which has a unnatural space (i.e:", instead of a natural dos space [i.e:'_') in it'
    Does anyone know what this is or what im doing wrong?
    Squid
  2. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    IFAIK, EasyDivX is no longer maintained - I suggest you look at avi.net or AutoGK - both are actually dead easy to use for DVD to AVI
    /Mats
  3. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    sounds like your choice of an output name is causing an issue. If all else fails, just call it "a" or whatever, and rename it latter.
    Google is your Friend
