Hello,
I am doing a short film on Final Cut and I need to zoom in on a specific part of a still image. The image is of the UK and I need to zoom in on the London area.
The image is a basic 2 colour outline of the UK (blue water, green land). London is therefore in the bottom right of the screen. I want the image to stay static for 1 second, then have the view slowly zoom in on the london area. The zoom will last for approx 3 seconds and the final frame will be of the whole screen green (as all you can see is the land).
Can someone explain how I can mark London on the map so that Final Cut will zoom in on that specific part of the map?
Thanks alot!
No idea on Final Cut, but I think the 3rd sample movie in the Photo to Movie gallery shows kinda what you're looking for. Photo to Movie can export to a Final Cut compatible format, tho'.
Drag the picture into the timeline, make sure it is the desired length. Change over to view Wireframe and set a keyframe. Advance the time forward as much as you want, drag the corner to expand the size of the picture and set a new keyframe. Go back to normal view.
Import Premier Pro 1.5 Project into Final Cut Pro/Studio 3 - how please?
By rjamesd05 in forum MacReplies: 1Last Post: 6th Sep 2010, 13:50 -
Final Cut Pro
By masaeurope in forum ffmpegX general discussionReplies: 7Last Post: 10th Mar 2010, 17:58 -
16:9 in Final Cut Pro
By malibu in forum MacReplies: 2Last Post: 5th Jul 2008, 08:41 -
final cut express and final cut pro 6
By ednarophati in forum MacReplies: 1Last Post: 16th Jul 2007, 10:05 -
Final Cut Pro / Soundtrack Pro Link Problem
By scottrwn98 in forum MacReplies: 11Last Post: 1st Jun 2007, 10:36
