Using the new build for the first time, input is .avi (mpeg4 xvid) with mp3 sound, approx filesize 370 mb, XP sp2, .NET framework 1.1, 2.6 ghz HT processor, 512 mb RAM.
After a couple of minutes in the conversion process i get error message:
Version: SVCD2DVD 2.0
Build: 2.0.2146.38069
Type: System.NullReferenceException
Source: DevComponents.DotNetBar
Message: Object reference not set to an instance of an object.
InnerException:
StackTrace: at DevComponents.DotNetBar.Balloon.6E()
at DevComponents.DotNetBar.Balloon.Dispose(Boolean disposing)
at System.ComponentModel.Component.Finalize()
The process seems to continue though, but what is this error and will it affect the final result (if any)?
Results 1 to 9 of 9
It is one of the GUI components throwing an error. It will not effect the processing. Do you get it all the time or just this once?
As being the first time using this particular build i cant really answer that, except that it never occured in the previous version.Originally Posted by ChrissyBoy
IŽll try another conversion today and repost the reults of that one.
On a side note, the process seems a bit faster with this build than the previous. Looks like itŽs really taking advantage of the HT technology......also CPU and mem usage seems a bit lower......conclusion is: All is well on the western front
Tried another conversion with a 700 mb xvid mpeg4 file, exact same settings as before, no problem whatsoever.
Tried the first file again, another error message shows again:
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
at System.Windows.Forms.UnsafeNativeMethods.DispatchM essageA(MSG& msg)
at System.Windows.Forms.ComponentManager.System.Windo ws.Forms.UnsafeNativeMethods+IMsoComponentManager. FPushMessageLoop(Int32 dwComponentID, Int32 reason, Int32 pvLoopData)
at System.Windows.Forms.ThreadContext.RunMessageLoopI nner(Int32 reason, ApplicationContext context)
at System.Windows.Forms.ThreadContext.RunMessageLoop( Int32 reason, ApplicationContext context)
at System.Windows.Forms.Application.RunDialog(Form form)
at System.Windows.Forms.Form.ShowDialog(IWin32Window owner)
at x3284ccece41ee22b.x210ff09a2516b1a7.x6341f549d2d05 feb(Object xe0292b9ed559da7d, EventArgs xfbf34718e704c6bc)
at DevComponents.DotNetBar.DotNetBarManager.C6(BaseIt em 3FI)
at DevComponents.DotNetBar.BaseItem.RaiseClick()
at DevComponents.DotNetBar.BaseItem.InternalMouseUp(M ouseEventArgs objArg)
at DevComponents.DotNetBar.PopupItem.InternalMouseUp( MouseEventArgs objArg)
at DevComponents.DotNetBar.ButtonItem.InternalMouseUp (MouseEventArgs objArg)
at DevComponents.DotNetBar.GenericItemContainer.Inter nalMouseUp(MouseEventArgs objArg)
at DevComponents.DotNetBar.Bar.OnMouseUp(MouseEventAr gs e)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at DevComponents.DotNetBar.Bar.WndProc(Message& m)
at System.Windows.Forms.ControlNativeWindow.OnMessage (Message& m)
at System.Windows.Forms.ControlNativeWindow.WndProc(M essage& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 1.0.5000.0
Win32 Version: 1.1.4322.2032
CodeBase: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll
SVCD2DVD
Assembly Version: 2.0.2146.38069
Win32 Version: 2.0.2146.38069
CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2/SVCD2DVD.exe
CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
System
CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
System.Drawing
CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll
Assembly Version: 5.2.0.0
Win32 Version: 5.2.0.5
CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2/DevComponents.DotNetBar.DLL
AxInterop.CodeLock
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2/AxInterop.CodeLock.DLL
System.Xml
CodeBase: file:///c:/windows/assembly/gac/system.xml/1.0.5000.0__b77a5c561934e089/system.xml.dll
System.Design
CodeBase: file:///c:/windows/assembly/gac/system.design/1.0.5000.0__b03f5f7f11d50a3a/system.design.dll
Accessibility
Win32 Version: 1.1.4322.573
CodeBase: file:///c:/windows/assembly/gac/accessibility/1.0.5000.0__b03f5f7f11d50a3a/accessibility.dll
Interop.CodeLock
CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2/Interop.CodeLock.DLL
Interop.QuartzTypeLib
CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2/Interop.QuartzTypeLib.DLL
Interop.DexterLib
CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2/Interop.DexterLib.DLL
System.Management
CodeBase: file:///c:/windows/assembly/gac/system.management/1.0.5000.0__b03f5f7f11d50a3a/system.management.dll
Interop.NEROLib
Assembly Version: 1.3.0.0
Win32 Version: 1.3.0.0
CodeBase: file:///C:/Program%20Files/BadgerIT/SVCD2DVD%20v2/Interop.NEROLib.DLL
CustomMarshalers
CodeBase: file:///c:/windows/assembly/gac/custommarshalers/1.0.5000.0__b03f5f7f11d50a3a/custommarshalers.dll
This error message seems to be referring to the same things as the one before, if i am not mistaken. -
Are you previewing when you get this error?
No Sir, i usually always skips previewing during the conversion process.Originally Posted by ChrissyBoy
Mmm. It is after you have clicked something... what did you do just before you got the error?
Loaded the asset (the movie with one subtitle stream) took a quick sneakpeak in the preview window, stopped the preview and checked my settings, and then started the conversion process. A couple of minutes later the error screen shows up, but the conversion goes on and the result is absolutely error free. This is what happend the first time i tried that file. The second time (as reported above) i used the exact same procedure, but this time another type of error screen shows up (my second copy-and-paste above) stating (as far as i understand) that the same error occured. But......this time it is even before the start of the process, when trying a sneakpeak preview.Originally Posted by ChrissyBoy
Looks like the first one is a SVCD2DVD error screen and the second one is more of a Windows XP related error screen? Might be wrong there though......The second screen is mentioning something about JIT-debugging......way beyond my knowledge anyway
Checking the main log shows one warning message: Warning, QMAT_SHIFT is larger then 21, overflows possible. This message shows up twice, otherwise thereŽs no problems whatsoever reported.
I am using custom matrice CCE Medium Low 2500-3200, no menu, automatic chapters every five minutes.
IŽll try to reproduce the error using the same file again and post screenshots of whats actually taking place. -
IŽve tried two more conversions with the same file as above but i cant seem to reproduce the error. Might have been a temporary glitch in my computer, i dunno.
IŽll be back..................with more info and screenshots if the error occurs again
VirtualDub Error Message - Video Compression Error
By HartsVideo in forum DVD RippingReplies: 19Last Post: 7th Jun 2009, 21:18 -
Error in Build 5000
By ttyner in forum SVCD2DVD & VOB2MPGReplies: 13Last Post: 9th Dec 2008, 14:25 -
Applescript error in Leopard build 9A527
By rbrakes in forum ffmpegX general discussionReplies: 14Last Post: 17th Dec 2007, 13:18 -
Error when encoding to mpeg using mencoder celticdruid build.
By freebird73717 in forum Video ConversionReplies: 3Last Post: 30th Aug 2007, 23:51 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 17:41
