Results 1 to 12 of 12
    Oct 2005
    Canada
    Ok, I tried to burn my already authored .vob, .bup, and .ifo files with CopytoDVD, Nero, Tmpgenc, DVD-lab, IFOedit, DVDShrink, and DVD Decrypter but everytime I try to play it in my DVD player it always says "Incorrect Disk". However, the disk plays fine on my computer, so what's the problem then?
  2. Member Sifaga's Avatar
    Aug 2003
    Melbourne, Australia
    the player dosnt like the disk
    try different media
  3. Member yoda313's Avatar
    Jun 2004
    The Animus
    Did you burn the video_ts and audio_ts folders as well????
    Or did you remember to finalize the disc?
    Two main steps to remember are to include both the audio_ts and video_ts folders of the dvd:
    example D:\
    audio_ts
    video_ts
    They are the main directories. That is what the dvd player is looking for.
    Also you have to do disc at once or click "finalize" or some such terminology depending on the software to make it a finished disc.
    That is of course assuming the files were authored correctly.
    Apr 2003
    Largo, FL
    Also be sure that your player can read the type of disk you're burning. Most newer players will read both +R and -R, but some won't. Older players are more likely to have a problem with +R.
  5. Retired from video stuff MackemX's Avatar
    Nov 2002
    VIP Lounge
    Hi and welcome to the forums
    I'd agree with BobK and say +/- issues or the fact your player doesn't like that media as my first thoughts
    maybe you can answer a few questions
    what is your standalone player?
    is it + or - you are using and what brand is it?
    how did you get the files in the first place?
    did you rip and compress a DVD?
    is this your first DVD burn?
    just because it works in your PC won't matter as most times they play a lot more media or faulty discs that won't play in a standalone
    Oct 2005
    Canada
    yes i burned the video_ts and audio_ts folders too
    how do i find out if it's +/-?
    my standalone player's a toshiba sd-v291u and a toshiba mw27f11c (the second one's my tv that has a vhs and dvd player built into it) both of them were bought recently so they can't be old
    i downloaded the files from the internet
    no i didn't rip the dvd (i'm sorry for asking this, but what does compress mean? i can't really understand the definition in the glossary )
    yes this is my first burn
    yes i'm sure my dvd player can read the type of disk i'm burning
    yes i finalized the disk
    when you say "change the media" do you mean change the type of disk i'm burning it on?
    also, the files were already authored when i downloaded it off the internet. only the thing i tried to burn with dvd-lab and copytodvd were mpeg-2 files when i first got them and had to author them myself
  7. Retired from video stuff MackemX's Avatar
    Nov 2002
    VIP Lounge
    no i didn't rip the dvd (i'm sorry for asking this, but what does compress mean? i can't really understand the definition in the glossary)
    I'd keep the fact you got the files from the internet to yourself in the future as it will only raise an eyebrow . Make sure you are aware of the rules before posting more information about this DVD as I've seen it many times before
    Oct 2005
    Canada
    is it still considered illegal if the files i'm burning is never going to be released onto dvd? like, they'll show it on tv once and that's it.
  9. Retired from video stuff MackemX's Avatar
    Nov 2002
    VIP Lounge
    I would say yes but I'm sure someone else will give a more definite answer
    Oct 2005
    Canada
    but these shows are shown in the other side of the world and the only way i can watch them is by downloading since they don't release them
  11. Retired from video stuff MackemX's Avatar
    Nov 2002
    VIP Lounge
    it still doesn't matter if it's unavailable in your country and I'd stop while the going is good before you get a warning as each reply digs you a deeper hole
    Like I said I've seen it many times before
    enjoy
    Oct 2005
    Canada
    fine then
