Ok i was about to copy an Audio CD and i use standard intenso 80/700 disks, That is the standard isnt it because it copied CD2 but not CD1 as there wasnt enough space.
This is the second time its happened and i have tried 2 differnet makes of CD's.
Is it a problem on the sources behalf not making it small enough or my fault for not having better disks and if so what would you reccommend me getting?
Try using software that will make an exact copy (disc to disc). I bet you are having problems in an intermediate step some place like ripping to wave and then burning to an audio CD.
I would use Taiyo Yuden CD's.
Audio has problems in Windows Media Player but not in other audio apps
By brassplyer in forum Software PlayingReplies: 7Last Post: 23rd Sep 2011, 16:12 -
audio broken in all media files
By amarkudre in forum Newbie / General discussionsReplies: 1Last Post: 7th Nov 2010, 03:14 -
No audio with Media Player Classic
By Compultion in forum Software PlayingReplies: 1Last Post: 4th May 2009, 03:51 -
Where did my audio go? No sound with media files!
By tmh in forum ComputerReplies: 5Last Post: 3rd Mar 2008, 20:39 -
Media error? Audio out of sink?
By overloaded_ide in forum MediaReplies: 5Last Post: 17th Oct 2007, 11:56
