Results 1 to 9 of 9
  1. hi is there a way i can make screen captures from a video, like WMV or RM video files?? any programs recommended?
    i tried using the keys print screen and sysRq on my keyboard, but that did not capture the video area of the screen (video area had a black screen), just everything around it.
    thanks
    read https://www.videohelp.com/forum/viewtopic.php?t=239865
    For wmv,rm use for example media player classic, file->Save Image. Install real alternative to play rm with media player classic.
    Mar 2003
    Kansas City MO
    Are you wanting to capture the whole streaming video? You used the term screen capture, which is just like a snapshot. What is it you are wanting to do?
  4. first of all thanks for all the help!
    i just want to make a snap shot from a video file and make that shot a image file, like jpg or gif.
  5. Member zoobie's Avatar
    Feb 2005
    Florida
    print screen?
    Apr 2003
    Maryland
    Won't work in most case as video is an overlay though you can cancell that ion some players. If not you may simply grab a black / blank frame. Most video playback tools, specially the DVD ones have a frame capture capabilities.
    No DVD can withstand the power of DVDShrink along with AnyDVD!
  7. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    ... or turn off overlays in said player. Then prntscrn should work.
    If in doubt, Google it.
  8. thanks for all the help! i solved the problem
    i downloaded real alternative .. and used the 'save image' option to make the captures.
