Can someone please tell me how to convert .mov files to mpg2 using FREE software ???
I've looked around and can't find anything that works. It's mostly crap that doesn't work at all or shitty trial versions that watermark the files or convert only a certain percentage of it.
Please help me !
You could try avisynth and import the avs script with quenc.
https://www.videohelp.com/guides.php?guideid=856#856
But it wont work with all kinds of movs...mov is a container that can contain a lot of different video and audio codecs.
You can also try mencoder, http://64.233.183.104/search?q=cache:3bYNRwhdzSwJ:www.videohelp.com/forum/viewtopic.ph...ient=firefox-a -
I've not found a "good" solution, but I've been able to convert by using Rad Video Tools to extract the video to AVI. Then I use Audacity to RECORD the audio while the .mov is playing. (I haven't found anything that works to extract the audio correctly.) I then pull them into virtualdub and adjust the a/v sync, then frameserve to Quenc to get to mpg2. As I said, it's not a "good" solution, but it works.
I have also tried to use Avisynth to convert using DirectShowSource, but the result was out of sync by the time it was converted to mpg2/DVD specs. But I have only tried it on one source .mov and there may have been a problem with it."Shut up Wesley!" -- Captain Jean-Luc Picard
Buy My Books -
You could try QuickTime alternative codec to read your mov file (it contains all the officiel quicktime codecs).
Then Avisynth should be able to read it through DirectShow
Best Freeware to Convert mov to avi?
By w6rlf in forum Video ConversionReplies: 5Last Post: 4th Feb 2012, 23:03 -
Which freeware (or paid tool) to cut easily HD movies (MOV,MTS)in 2 pieces?
By innovator in forum Video ConversionReplies: 1Last Post: 27th Nov 2010, 04:16 -
mencoder wont convert the complete file, mov to avi|mov
By bjornieB in forum Video ConversionReplies: 2Last Post: 19th Nov 2009, 07:42 -
AVI to mp4 Freeware and VOB to mp4 Freeware
By saucedmike in forum Newbie / General discussionsReplies: 2Last Post: 1st Jan 2008, 01:44 -
Freeware ideas to show two similar MOV files for best one compare?
By j_hallgren in forum Newbie / General discussionsReplies: 1Last Post: 24th Sep 2007, 19:50
