- I mainly use version 1.x, had it for several years now, no complaints.
- I've had version 2.x for a little while now, on a second computer.
- And I've used the Express one a couple times in the past, mostly just demos, betas and trials given to me for review purposes..
Procoder 1.x still looks best. Pretty close to realtime encoding, clean quality, nothing wrong. Added bonus is file sizes can often end up lower than other encoders AND still be higher quality. Double the fun.
Procoder Express is a lot like a stripped down Procoder 2.x and mostly only does DV style encoding for DVD output. It's alright, $50 is fine for it, does a decent job for making 720x480 DVDs
Procoder 2.x is odd. It's faster when it shouldn't be, mastering quality can look worse than highest, and I finally saw a video come out soft a few days ago (although it may be random or based on factors I've not narrowed down yet). Most of the time it works as good as version 1 with some extra filters. But sometimes not. Strange.
I need also add most of the 1.x and 2.x encodes are Half D1 work. Still no problems for Full D1 work.
I know people have discussed this software in length here in the not-so-distant past, thought I'd share some updated experience and observations. Most people, of course, won't care, as this software is priced well above what they'd need.
If I recall Procoder Express is lacking an option found on Procoder 2.x (and maybe Procoder 1.x) that has something to do with luminance levels and this was a big deal in another thread.
I don't use Procoder but that seems like an important point to bring up.
Maybe someone else can fill in the details here on this issue.
Another thing is Procoder 1 and 2 have "cheats" that let you either edit or create your own altered DVD-compliant MPEG templates.
Express lacks the ability of advanced settings, and by default it disables sequence headers. So using anything OTHER THAN the DVD template will make non-compliant MPEG streams.
Procoder 2 is the same way, but it DOES have advanced settings so you check the sequence headers option.
Procoder 1 never disabled sequence headers, you had to do it manually or start with a generic MPEG template and never select DVD or that option.
If that makes sense. You'd probably have to see it to understand. But it is aggravating.Want my help? Ask here! (not via PM!)
I stand up next a mountain and chop it down with the ledge of my hand........ I'm a Voodoo child.... Jimi Hendrix,
Have only ever used Procoder 2 and it was for PAL/NTSC conversion...it did a great job of that...Losing the 5.1 audio to 2 channel stereo was a bummer but I didn't mind.I liked my results w/ PC2 over tmpg but tmpg wasn't too bad either.Now if I get a PAL region...I just run it through PC2 and never look back....Now if they had an authoring app like tmpg does canopus would have something....
I had a post about this not a long time ago...
I used both, and didn't see any difference, maybe because I don't use it that much avery day. -
Originally Posted by FulciLives
About the 601 to 709 colorspace conversion thing.
This seems to only crop up with DV footage, correct?
There are a number of DV codecs but there is a Canopus DV codec and of course Canopus makes Procoder so you would think that the Canopus DV codec would work "correctly" with Canopus Procoder (any version).
I'm wondering if the problem has something to do with using a DV codec other than the Canopus DV codec?
Also I wonder if the 601 to 709 thing can be done before feeding the DV file to Procoder Express using something like AviSynth. For instance maybe you can adjust 0-255 to 16-235 (assuming this is what the 601 to 709 option does) in AviSynth and then have a similiar effect using Procoder Express as you would without AviSynth but use Procoder 2.x with the 601 to 709 option?
See what I am saying?
Tis a thought.
Canopus Procoder: chapters in DVD-export? How?
By Lippy Lipstick in forum Authoring (DVD)Replies: 4Last Post: 20th Dec 2008, 05:09 -
Canopus Procoder Help
By spliffy in forum Video ConversionReplies: 3Last Post: 15th Nov 2008, 03:07 -
Encoding progressive NTSC material with Canopus Procoder 1.5?
By zee944 in forum Video ConversionReplies: 8Last Post: 13th Oct 2008, 07:56 -
Canopus Procoder Cropping
By spliffy in forum EditingReplies: 1Last Post: 20th Dec 2007, 21:25 -
Anybody tried Canopus ProCoder 3?
By cosmin in forum Video ConversionReplies: 1Last Post: 16th Oct 2007, 21:25
