Gday guys,
My Dad went on holidays recently and came back with all his DVD Camcorder footage on his laptop (he only had 1 Ram disk so he kept transferring onto the laptop). Anyways he has asked me to put all the footage onto DVDR for him. Whats the best way to go about getting these VRO files onto DVDR?
I have read some other threads here and accordingly renamed the VRO's to mpg. They seem to play fine though media player says they are only 6 secs long, they keep playing after the time bar has got to the end. So, when I go to author I cant put chapters in the video.. Does that make sense?
Thoughts?
~Firefly - Keep Flying~
tried tmpgenc dvd author? select add dvd video and select the folder with the vro files.
Thanks Baldrick, I haven't tried tmpgenc dvd author as we have had a few disagreements over the years.. Does tmpgenc dvd author accept vro's "as is" without being renamed as mpg's? If so does that mean that the timecodes(I think thats the right word) will be intact and thus the videos should be able to be chaptered?
~Firefly - Keep Flying~ -
Or you can just put VRO in the search box on the top of this page, select 'all forums', you should find a lot to read.
Editing Panasonic Burner DVD-RAM VRO Video In Computer
By Teshia in forum User guidesReplies: 47Last Post: 18th Feb 2013, 09:06 -
Problems copying .VRO files from DVD-RAM -- SOLVED!
By usually_quiet in forum DVD RippingReplies: 14Last Post: 2nd Jun 2011, 17:30 -
Need To Split A DVD-RW .VRO File
By 360Spider in forum DVD RippingReplies: 2Last Post: 21st Jun 2010, 12:55 -
RAM .vro files to usable format?
By nelsh in forum Newbie / General discussionsReplies: 2Last Post: 6th Nov 2007, 20:05 -
Extracting .VRO file from DVD-RAM to pc for editing
By mattsz in forum Newbie / General discussionsReplies: 9Last Post: 13th Jun 2007, 14:25
