I've got a hacked Sony TRV-120E (Digital 8) with analog inputs enabled. I've run into some problems with analog in, though: when trying to digitize signal from a VHS source, the picture is usually overbright (with some white clipping), sometimes B/W and after 10-20 secs it somehow loses the sync altogether and refuses to capture anymore.
I've tested the analog input with three sources. The composite signal from a Playstation works perfectly, as does my Canon Powershot. I could imagine the signal from a VHS tape were so poor that it causes the loss of synchronization etc. but the same effects occur if I try to capture a rather clean signal from the TV tuner of the vcr.
I'm using an in/out scart adapter with the vcr, could it affect the quality of the signal? Or could the problem be due to ground loops? Or is the vcr just a piece of crap?
It doesn't affect if the camera is connected to the firewire adapter or not.
Sorry for a short answer, but I think its your VCR. Try another player, I feel pretty sure your problem will be solved.
If your trying to cap a tape with Macrovision, it may have the brightness problem you describe when playing with some (Ive had one) VCRs. Mostly though, you dont see this.
Good luck,
AndrewI have been into computers since 1980. Ive been tinkering with DV in one flavor or another since 1990. -
Thanks for answers, I'll try a different VCR. I got (possibly) more info about the problem: At least some of the Sony cameras simply don't seem to like certain (but few) VCR models. Bad luck.
Capture analog video from sony camcorder
By gthoman in forum Capturing and VCRReplies: 14Last Post: 14th Apr 2009, 14:32 -
Using Analog Sony Handycam as a Webcam
By whataboutbob in forum Capturing and VCRReplies: 2Last Post: 28th Jan 2009, 18:18 -
copying analog 8mm to mac using sony digital 8 and firewire
By iampammyb in forum MacReplies: 4Last Post: 15th Nov 2008, 00:15 -
Urgent Question Sony CCD-TRV438E Hi-8 Analog Camcorder
By Shaga in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 20th Oct 2008, 13:32 -
Analog to digital pass through with Sony Handycam DCR- HC65
By Gerald Sr. in forum Capturing and VCRReplies: 3Last Post: 30th Sep 2008, 23:18
