The only problems I've had with TMPGenc DVD Author is once it made a vob with a negative length? Couldn't reuse for next project. Solved that by demuxing it.
The second one is annoying though. I need a lot of chapter points at specific times, as I make instructional videos. I usually have all my chapter times sitting in a spreadsheet program. With DVDAuthorGui I just paste the list of chapter times in, but with TMP I have to add each one manually and then enter yes when I get that annoying pop-up telling me I can't start a chapter here, would I like it to choose the closest available point.
(Why would I answer no?)
Am I missing something? Is there a better way to add chapter points?
Results 31 to 36 of 36
Originally Posted by jimmalenko
Check out this motion menu which I authored with TDA ...Originally Posted by Beldvd
https://www.videohelp.com/forum/viewtopic.php?p=1412661#1412661
While TDA has some limitations your ability to make customized motion menus is much greater than most users realized.
Would you consider the motion menu I made, which is shown in the above link, a beginner's menu? By the way ... the motion menu I made runs for the length of the Move It Music Video (around 3-minutes or so if I remember correctly) which is shown w/audio in the 360 x 240 window.Originally Posted by Beldvd -
The new version of TDA (Pro) will let you set chapters at any point. I'm not sure how you get the chapter times in a spreadsheet unless you're typing them in, and I don't imagine that would be any faster than setting them manually in TDA Pro.Originally Posted by trolltuning
BobK wrote:
Nice to know although I hate to spend $59 to upgrade one feature.The new version of TDA (Pro) will let you set chapters at any point. I'm not sure how you get the chapter times in a spreadsheet unless you're typing them in, and I don't imagine that would be any faster than setting them manually in TDA Pro.
I either type them in or paste them in from Womble timecode, or I paste the frame numbers from an Avisynth script and let the spreadsheet convert to times. Sometimes I need to add or subtract them. Then I let the spreadsheet format them so the authoring program will accept them. Obviously easier to paste them all in at once seeing as I have to do the other anyhow. -
That's understandable. It might not make any difference, but there are other differences besides that one feature. The most useful to me was the ability to quickly simulate the dvd before compiling so- mainly to check the direction of menu links (also has a button on the menu page that will show button the up/down and right/left buttons will go from each button.Originally Posted by trolltuning
Does re-authoring VOB files with TMPGEnc DVD Author, or DVD-lab better
By MarcMiller in forum Video ConversionReplies: 6Last Post: 16th Nov 2010, 01:31 -
Help with DVD-lab PRO.
By angles in forum Authoring (DVD)Replies: 2Last Post: 3rd Jan 2010, 18:19 -
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 12:10 -
DVD Lab Pro
By matthewjohn23 in forum Authoring (DVD)Replies: 5Last Post: 20th Mar 2009, 13:35 -
Q, for those who use DVD Lab Pro...
By GangstaRap in forum Authoring (DVD)Replies: 3Last Post: 1st Nov 2007, 07:15
